Author Topic: Very Strange Lag.  (Read 21882 times)
Offline fetz
Very Strange Lag.
« on: January 19, 2014, 03:30:57 pm »
I am hosting a Garry's Mod TTT Server on Linux (SteamCMD). Throughout playing player(s) walking will be choppy and going up/down ladders is really choppy. You can also walk through props.
My server is using 30% CPU usage and 50% RAM. Everyone has 40-120 ping. The servers upspeed is about 200 mb/s.
I am guessing it is something I am doing wrong starting the server?
I am only running pointshop addon plus some custom player models.
Thanks in advanced, Fetz
P.S. I hear a bunch about "Server FPS Lag"... how can I tell how much FPS my server is getting? Also here is the specs:
1024 MB of Guaranteed RAM
1024 MB of Swap
3 CPU @ 2.0+ Ghz
1 IPv4 Address
50 GB of Disk
2 TB of Bandwidth
Offline Neku
Re: Very Strange Lag.
« Reply #1 on: January 19, 2014, 04:05:48 pm »
Install CSS.
Or...
Get better host.
One of those will work.
Offline Neku
« Reply #2 on: January 19, 2014, 04:09:41 pm »
Actually, where is the server physically located?
Offline fetz
« Reply #3 on: January 19, 2014, 04:16:15 pm »
Is located in New York. My host is fine.
I app_update'd CSS.
It still didn't fix it. Do I have to app_update CSS in a certain directory?
Offline Neku
« Reply #4 on: January 19, 2014, 04:20:16 pm »
Do your players live near New York?
I manually upload CSS to the addon folder.
app_update isn't reliable.
« Last Edit: January 19, 2014, 04:22:31 pm by Neku »
« Reply #5 on: January 19, 2014, 04:43:36 pm »
Using app_update is fine as long as you make sure to set up your mount.cfg properly.
Here is what mine looks like:
// Use this file to mount additional paths to the filesystem
// DO NOT add a slash to the end of the filename
"mountcfg"
"cstrike" "C:\gameservers\garrysmod\gmstranded\cstrike"
While I'm not 100% sure on this, I would imagine it is far more efficient to load an entire game's worth of content as a mount than through the addons folder.
Offline Neku
« Reply #6 on: January 19, 2014, 04:52:27 pm »
Well...it's more of a preference thing.  :)
« Reply #7 on: January 19, 2014, 05:20:43 pm »
"mountcfg"
Make sure to alert him of the need of changing the directory. :P
"mountcfg"
"cstrike" "<INSTALL PATH FOR CSTRIKE>"
:p
Offline fetz
« Reply #8 on: January 19, 2014, 05:58:41 pm »
"mountcfg"
And I should add this to lua/autorun?
« Reply #9 on: January 19, 2014, 06:53:47 pm »
No. This should go to your server's /cfg/ directory.
Sorry, shoulda pointed that out as well. :P
Offline fetz
« Reply #10 on: January 20, 2014, 12:30:00 pm »
Alright. Sounds easier to just drag cstrike folder into addons? This should work too right?
Offline Neku
« Reply #11 on: January 20, 2014, 01:23:14 pm »
Yeah, pretty much.
Offline fetz
« Reply #12 on: January 20, 2014, 02:00:29 pm »
Installed htop to moniter the CPU and RAM... they never go over 60% and yet I am still getting lag on the server. Everyones ping is below 100.
Offline Neku
« Reply #13 on: January 20, 2014, 02:19:02 pm »
You realize low ping is a good thing, right?
« Reply #14 on: January 20, 2014, 02:27:15 pm »
If he doesn't...
*facehoof*
Ping is the time (in milliseconds) it takes for your client to respond to a request sent out by a server. The lower, the better.
