Author Topic: Very Strange Lag.  (Read 21882 times)
Offline fetz
Re: Very Strange Lag.
« Reply #15 on: January 20, 2014, 03:08:58 pm »
Yes I know low ping is good.
I am just pointing out that the ping(s) are very good. Also CPU and RAM is very good. Yet the server is still lagging.
Thanks, Fetz
Offline fetz
« Reply #16 on: January 20, 2014, 03:12:39 pm »
Also I still notice you can walk through props even after moving cstrike folder into my addons folder.
But some props you CAN'T walk through anymore. Should I also move hl2 into addons folder?
« Reply #17 on: January 20, 2014, 03:25:11 pm »
What props can you walk through?
You don't need to move HL2. garrysmod comes with HL2 props already.
Your map may be using Episode2 or Episode1 or content from another game.
Take a screenshot of the prop(s) you can walk through and post it here please.
Offline fetz
« Reply #18 on: January 21, 2014, 05:28:07 pm »
Here is a couple of the model names on one map:
« Reply #19 on: January 21, 2014, 10:47:32 pm »
Those are CS:S. Moving the CS:S folder into your addons folder won't just WORK.
It would if you set it up like an addon, but it's not. You need to extract the models from the CS:S vcd files and move them into your garrysmod root. Or just mount CS:S properly.
Offline fetz
« Reply #20 on: January 24, 2014, 07:35:44 pm »
The props I can still walk through. Here is my mount.cfg (I am on linux)
// Use this file to mount additional paths to the filesystem
// DO NOT add a slash to the end of the filename
"mountcfg"
// "cstrike" "/home/steam/css/cstrike"
// "tf" "C:\mytf2server\tf"
« Reply #21 on: January 24, 2014, 08:07:34 pm »
"mountcfg"
I hope css is actually installed to that directory..?
:P
Offline Neku
« Reply #22 on: January 24, 2014, 09:00:35 pm »
Well, I'd say your issue is that cstrike is not being mounted and is being commented out...
« Reply #23 on: January 24, 2014, 09:28:44 pm »
Indeed. // = comment for mount cfg
Offline syn.
  • Lua Padawan
    • SynGaming
« Reply #24 on: January 24, 2014, 09:39:28 pm »
lmao xD
Lua Student
"The more you understand, the crazier you get."
« Reply #25 on: January 24, 2014, 09:45:49 pm »
lmao xD
Not that funny syn. :)
What gets printed in below lua code?
  print "Hello"
  print "World"
  print "I"
--print "Hate"
--print "You"
--print "I"
  print "Love
  print "You"
Offline syn.
  • Lua Padawan
    • SynGaming
« Reply #26 on: January 24, 2014, 10:01:44 pm »
Hello World I Love You :) cmon Jam give me something harder :D
(to be honest you almost got me)
Lua Student
« Reply #27 on: January 24, 2014, 10:08:36 pm »
Trick question, half right.
Print " " would produce errors. True lua print command would be print ("<string>")
You got the idea on comments in lua though. -- is the true way. Garry added C style /* code */
Now, back on topic. Lag/css mounting.
Sorry, beyond my experience.
Google would be my friend, along with what little is in the gmod wiki.
Offline fetz
« Reply #28 on: January 25, 2014, 04:43:34 am »
Wow I feel really stupid xD
« Reply #29 on: January 25, 2014, 05:33:08 am »
Make sure that the directory of the cstrike folder is actually correct, and don't just uncomment it.
