Author Topic: Can't see permissions and teams?  (Read 14939 times)
Offline eagle9er9er
« on: August 03, 2014, 12:07:43 pm »
Anyone else having this issue? I can't edit a groups team, or permissions. I have to use console now. I know the teams and permissions are there. But it won't show up in xgui. This problem came out of nowhere, I don't remember really doing anything before hand that might have caused it.
« Last Edit: August 03, 2014, 12:15:23 pm by eagle9er9er »
Re: Can't see permissions and teams?
« Reply #1 on: August 03, 2014, 01:33:40 pm »
This is probably related to this issue, which I'm investigating: https://github.com/Nayruden/Ulysses/issues/296
As I stated in the comments, you can temporarily fix the issue when this occurs by running the following two commands in your client console:
_xgui datacomplete
xgui getdata
EDIT:
You may also want to check and make sure you have the latest ULX/ULib from our github page linked above. (Can use SVN links from there if you prefer.) I think the ULib version should at least say "2.52"
« Last Edit: August 03, 2014, 01:35:19 pm by Stickly Man! »
Offline eagle9er9er
« Reply #2 on: August 03, 2014, 02:17:36 pm »
I get "XGUI: Command datacomplete not recognized!" and the menu is still blank after refreshing everything.  :( I will try adding new ulib right now.
« Reply #3 on: August 03, 2014, 02:41:30 pm »
Sorry, I typoed- it is case sensitive: "xgui dataComplete"
Offline eagle9er9er
« Reply #4 on: August 03, 2014, 04:04:41 pm »
No luck :( Still blank.
Offline JasonMan34
« Reply #5 on: August 04, 2014, 06:09:25 pm »
I have a question for you.
Do you have a custom ULX addon? Such as aafk or Auto promote?
Offline eagle9er9er
« Reply #6 on: August 04, 2014, 09:06:14 pm »
Yes both.
Offline JasonMan34
« Reply #7 on: August 05, 2014, 04:30:39 am »
Yes both.
Remove auto promote.
If this started after the gmod update, that's your problem.
Idk why but when I added it to my TTT server EVERYTHING got <MESS>ed up.
Maps didn't work, almost all of the ulx commands were broken, I got spammed with lua errors from the gamemode folder....
Try removing it and restarting, should fix it
« Last Edit: August 05, 2014, 07:58:03 am by JamminR »
Offline Neku
« Reply #8 on: August 05, 2014, 07:24:47 am »
You haven't updated ULX to the latest SVN, haven't you?
Auto-Promote is working fine for me.
« Last Edit: August 05, 2014, 07:57:43 am by JamminR »
Offline JasonMan34
« Reply #9 on: August 05, 2014, 07:28:57 am »
I have, Stickly Man even approoved it :P
Auto-Promote <MESS>ed everything up for my TTT server, that I can say for sure
« Last Edit: August 05, 2014, 07:57:10 am by JamminR »
« Reply #10 on: August 05, 2014, 07:56:38 am »
Jason, please watch the language here. We try to keep it clean for all ages.
(And Neku, please be careful about quoting those who use such language)
Thanks.
« Last Edit: August 05, 2014, 07:58:50 am by JamminR »
Offline Neku
« Reply #11 on: August 05, 2014, 12:14:25 pm »
My bad, it was 7ish AM when I wrote that.
Offline JasonMan34
« Reply #12 on: August 05, 2014, 01:33:58 pm »
Thanks.
Sorry, didn't realize that >_>
But if it's not auto-promote it's probably a different addon, have you tried re-installing ULX without any custom files in it?
Offline eagle9er9er
« Reply #13 on: August 10, 2014, 03:55:49 pm »
I've been reinstalling ulx, with and without custom files and still cant see group permissions.
Edit: On another note, I am getting this error when trying to rename a group.
[ERROR] addons/ulx svn2/lua/ulx/xgui/server/sv_groups.lua:268: bad argument #1 to 'ipairs' (table expected, got nil)
1. ipairs - [C]:-1
2. renameGroup - addons/ulx svn2/lua/ulx/xgui/server/sv_groups.lua:268
3. call - addons/ulx svn2/lua/ulx/modules/sh/user.lua:282
4. __fn - addons/ulib svn2/lua/ulib/shared/commands.lua:943
5. unknown - addons/ulib svn2/lua/ulib/shared/commands.lua:1296
6. unknown - lua/includes/modules/concommand.lua:69
« Last Edit: August 10, 2014, 06:58:37 pm by eagle9er9er »
Offline lonewaft
« Reply #14 on: August 12, 2014, 04:38:06 pm »
typing _xgui dataComplete into the console fixes the issue for me, but I have to do it everytime I see this bug, is there a permanent fix?
