Author Topic: Can't see permissions and teams?  (Read 14939 times)
Offline Stranger Danger
Re: Can't see permissions and teams?
« Reply #15 on: August 13, 2014, 01:03:04 pm »
_xgui dataComplete doesn't even fix it for me.
Offline xombob
« Reply #16 on: August 14, 2014, 06:19:10 am »
Im having this exact same problem all of a sudden, but in addition the "!menu" and "xgui show" commands dont work while every other ulx command does...
I can confirm xgui dataComplete will fix this temporarily, but its gonna get annoying if I have to type it in every time.
« Reply #17 on: August 15, 2014, 10:51:52 am »
I'm still investigating the issue. https://github.com/Nayruden/Ulysses/issues/296
Just be sure you're running the latest version of our code from here: https://github.com/Nayruden/Ulysses as I've improved the ban menu, and am wondering if it has improved this issue.
Offline xombob
« Reply #18 on: August 22, 2014, 03:00:50 pm »
I noticed this glitch or w/e you want to call it doesnt appear on my other server, even tho they both have the same version. Which I guess would suggest that its caused by another addon (possible URS or Patch Prop Protect, since those were the most recent ones I added if I remember right). Unless if the gamemode can affect it?
Offline xombob
« Reply #19 on: August 30, 2014, 09:23:57 am »
I just removed Patch Protection but the problem with !menu is still there, so at least you can be sure its not that.
Are there any news on this problem other than the temporary fix?
EDIT: Also I just installed the newest versions of ulx and ulib but nothings changed.
« Last Edit: August 30, 2014, 09:33:18 am by xombob »
« Reply #20 on: September 02, 2014, 12:29:26 pm »
Still no news, sorry. I'm wanting to have a sit-down session with Megiddo to thoroughly look into the bug, but our schedules are both pretty hectic at the moment. And yes, the gamemode definitely can have an effect on this bug- Sandbox seems to be fine, DarkRP and TTT seem to have the most troubles with it.
