Author Topic: Is a ulx update coming for the new gmod update?  (Read 7882 times)
Offline casey d
« on: December 06, 2014, 07:24:20 pm »
Hello I am currently working on the dev gmod mode of dark rp and I noticed that ulx is kind of buggy transtionging into this patch. One of the major issuse is that I  can't seem to open the menu with the !menu command. But other commands like !motd run just fine. Sadly it doesn't seem to show anything in the RCON while I do it so I would check out the dev  gmod version of ulx yourself. It's interesting and also during transition I seemed to get this spamming my rcon. I do a factory reset on ulx and UlIB and I still keep on getting it.. Thanks for your support and I hope to see what happens next on ulx!
Image link if not working. https://imgur.com/Kb4Rgh6
« Last Edit: December 06, 2014, 07:25:53 pm by casey d »
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
Re: Is a ulx update coming for the new gmod update?
« Reply #1 on: December 06, 2014, 08:38:09 pm »
Don't take this the wrong way but it's you're fault. If ulx was according to your information 'that buggy', then it wouldn't be around for as long as it has been, nor would it be the leading administration system for garry's mod. There is an addon conflicting with ulx, could possibly be your dark rp server is conflicting with it, as you may have not gotten an official version of DarkRP, or have edited something you're not supposed to touch.
On the other hand, DarkRP works really well with ulx, as it has a modification called "FADMIN" (pretty sure it's called that), and it located in the TAB menu while playing DarkRP.
As I said somewhere above, you need to list all the addons you're using on your server. Easiest way is to check console at the beginning. I'll post below a code in red, and that's all the addons in your addons folder, and that's the easiest way for any of us to check what all your addons are, so just send us your list (same for if you're using working collaboration thing.)
My apologize ULX team, I know you guys hate long things, but I couldn't highlight in red with {code}
Console initialized.
Adding Path: [C:\garrysmod_server\cstrike]
FIND [C:\garrysmod_server\cstrike\*.vpk]
ADDING [C:\garrysmod_server\cstrike\cstrike_pak_000.vpk]
Adding Path: [C:\garrysmod_server\tf]
FIND [C:\garrysmod_server\tf\*.vpk]
ADDING [C:\garrysmod_server\tf\tf2_misc_000.vpk]
ADDING [C:\garrysmod_server\tf\tf2_scripts_000.vpk]
Adding Path: [C:\garrysmod_server\dod]
FIND [C:\garrysmod_server\dod\*.vpk]
ADDING [C:\garrysmod_server\dod\dod_pak_000.vpk]
Adding Path: [C:\garrysmod_server\hl2mp]
FIND [C:\garrysmod_server\hl2mp\*.vpk]
ADDING [C:\garrysmod_server\hl2mp\hl2mp_pak_000.vpk]
Adding Path: [C:\garrysmod_server\portal]
FIND [C:\garrysmod_server\portal\*.vpk]
ConVarRef mat_dxlevel doesn't point to an existing ConVar
Game.dll loaded for "Garry's Mod"
Initializing Steam libraries for secure Internet server
Logging into anonymous gameserver account.
Connection to Steam servers successful.
   Public IP is
Assigned anonymous gameserver Steam ID [A-1:1431694339(4942)].
VAC secure mode is activated.
Fetching Workshop Addons.. host_workshop_collection is unset
Adding Filesystem Addon 'c:\garrysmod_server\garrysmod\addons\apple_chat_prefixes'
Adding Filesystem Addon 'c:\garrysmod_server\garrysmod\addons\apple_join_disconnect_warning'
Adding Filesystem Addon 'c:\garrysmod_server\garrysmod\addons\apple_multi_server_chat_sql'
Adding Filesystem Addon 'c:\garrysmod_server\garrysmod\addons\apply_last_join_server_sql'
Adding Filesystem Addon 'c:\garrysmod_server\garrysmod\addons\pointshopmaster'
Adding Filesystem Addon 'c:\garrysmod_server\garrysmod\addons\ulib'
Adding Filesystem Addon 'c:\garrysmod_server\garrysmod\addons\ulx'
Adding Filesystem Addon 'c:\garrysmod_server\garrysmod\addons\ulx_auto_promote'
Adding Filesystem Addon 'c:\garrysmod_server\garrysmod\addons\ulx_force_respawn'
Adding Filesystem Addon 'c:\garrysmod_server\garrysmod\addons\ulx_give_weapon'
Adding Filesystem Addon 'c:\garrysmod_server\garrysmod\addons\ulx_playurl'
Adding Filesystem Addon 'c:\garrysmod_server\garrysmod\addons\ulx_set_model'
Adding Filesystem Addon 'c:\garrysmod_server\garrysmod\addons\ulx_set_utime'
Adding Filesystem Addon 'c:\garrysmod_server\garrysmod\addons\ulx_temp_adduser'
Adding Filesystem Addon 'c:\garrysmod_server\garrysmod\addons\utime_sql'
Network: IP 192.168.0.7, mode MP, dedicated Yes, ports 27016 SV / 27006 CL
PREP OK
Offline casey d
« Reply #2 on: December 06, 2014, 10:24:33 pm »
I have it where it is only ulx and luib and I still have same issues. Lol FAdmin works fine (Thank god) but if I really want to get into the xgui features I can't I require the !menu to get into it. Also heres what I got for now. (I have all my other addons in separate folder)
« Reply #3 on: December 07, 2014, 02:12:06 pm »
The only update coming to GMod up that I'm aware of that may be an issue is a change to the SteamID format. However, it doesn't seem to have made it to the dev build of GMod yet.
Offline casey d
« Reply #5 on: December 07, 2014, 08:41:13 pm »
Lol I'm happy i'm not the only one having this issue. I deleted my data/ulib and data/ulx folders and I still get the same issue. I think what ever addon or rouge code it is it's getting into the core and or main files. You are welcome to check out my server  if you guys need to
« Reply #6 on: December 07, 2014, 09:19:38 pm »
Someone here on the forums had exact same issue, and reported what they found/did to remove it.
/index.php/topic,7700.0.html#msg39197 />
Perhaps you got an addon from the same place.
« Reply #7 on: December 10, 2014, 03:56:08 pm »
Have you tried launching the addon on a fresh install of ulx/ulib, and removed the ulx/ulib data folders, as well as ran it in Sandbox? I'd try the barest of bear, and move up from there.
