Author Topic: Ulx Cannot Edit permissions.  (Read 5939 times)
Offline Cyan?
    • Orion Network
« on: December 31, 2014, 08:54:47 pm »
im an rank superadmin but i cannot edit the permissions at all.
*note: i have installed urs and removed it.
Screen shot:
http://gyazo.com/650c6b9f2b485f4c17d28ac3773fbcf8
Offline Caustic Soda-Senpai
    • Steam Page
Re: Ulx Cannot Edit permissions.
« Reply #1 on: December 31, 2014, 10:22:21 pm »
Try reinstalling ULX, post if the same issue occurs
« Reply #2 on: January 01, 2015, 11:59:51 am »
  • Disable FAdmin. FAdmin and ULX do not play well together.
  • Are you sure you're running the latest version of ULX/ULib from their Github? The "latest version" from their site is heavily outdated.
Offline Cyan?
    • Orion Network
« Reply #3 on: January 01, 2015, 02:02:08 pm »
removed*
« Last Edit: January 01, 2015, 02:03:41 pm by Cyan? »
Offline Cyan?
    • Orion Network
« Reply #4 on: January 01, 2015, 02:13:32 pm »
how do i install it?
Offline Cyan?
    • Orion Network
« Reply #5 on: January 01, 2015, 03:00:39 pm »
ok i reinstalled it and still dosent work
Offline XxLMM13xX
  • New to lua development
    • Twitch
« Reply #6 on: January 02, 2015, 10:55:59 am »
You can also check if you have ULX installed on your local addon file thing.... check your addons folder and see if ULX if in there. or go to sandbox singleplayer and type !menu if the menu pops up just look for ULX in your addons folder and delete it
« Reply #7 on: January 02, 2015, 01:41:04 pm »
You saying you uninstalled and re-installed it and "it doesn't work" is no help to anyone trying to help you because you're not giving detail as to what you've fully done and exactly what isn't working.
First, are you using our latest code from Github (zip available at https://github.com/Nayruden/Ulysses ). If using our 'release' at ulyssesmod.net/downloads.php, it's been broken by GMod a few times.
Second, have you tried disabling/removing all other addons/workshop or otherwise?
There are a few that "hack" ULX from working for everyone except the exploiter. (Just search this forum for the word "exploit", several posts exist, one even mentions which addon a user found to be bad.
When you "uninstalled" it, did you remove the data folders as described in our FAQ "How do I uninstall ULX/ULib?" (Removing the ADDONs folders is NOT enough, the DATA folders contain the permissions granted during use)
When you re-installed it, after PROPERLY uninstalling, did you add yourself as "superadmin", following the FAQ "How do I make myself admin? (3 simple foolproof methods)"
If the info and FAQs above don't help, then follow, step by step, the FAQ "Having trouble with access?"
When completing EVERY step in that FAQ, if you don't have access, come back with the information it requests.
