Author Topic: Need help to fix this code  (Read 7498 times)
Offline PwndKilled
« on: January 24, 2015, 10:32:08 am »
function FGod( ply, dmginfo )
if(ply:GetNetworkedVar("FGod") == 1) then
dmginfo:ScaleDamage( 0 )
hook.Add("EntityTakeDamage", "FGod", FGod)
hook.Add("PhysgunDrop", "ply_physgunfreeze", function(pl, ent)
hook.Remove( "PhysgunDrop", "ulxPlayerDrop" ) --This hook from ULX seems to break this script that's why we are removing it here.
ent._physgunned = false
if( ent:IsPlayer() && ( pl:IsUserGroup( "superadmin" ) or pl:IsUserGroup( "admin" )) ) then     --If you want to insert another one insert "or pl:IsUserGroup( "YetAnotherGroup" )"
-- predicted?
if(pl:KeyDown(IN_ATTACK2)) then
ent:Freeze(true)
ent:SetNetworkedVar("FGod", 1)
ent:SetMoveType(MOVETYPE_NOCLIP)
ent:Freeze(false)
ent:SetNetworkedVar("FGod", 0)
ent:SetMoveType(MOVETYPE_WALK)
if SERVER then
-- NO UUUU FKR
if !ent:Alive() then
ent:Spawn()
self:PlayerSpawn(ent)
ent:SetPos(pl:GetEyeTrace().HitPos)
else -- If it wasn't an admin in your defined groups then don't do anything
ent:Freeze(false)
return --self.BaseClass:PhysgunDrop( pl , ent )
end)
hook.Add( "PhysgunPickup", "ply_physgunned", function(pl, ent)
ent._physgunned = true
end)
function playerDies( pl, weapon, killer )
if(pl._physgunned) then
return false
return true
hook.Add( "CanPlayerSuicide", "playerNoDeath", playerDies )
I get error everytime i freeze somebody..it's annoying
Re: Need help to fix this code
« Reply #1 on: January 24, 2015, 10:46:35 am »
When presenting more than 3-4 lines of code and saying "this code isn't working", it would be helpful to everyone if you posted the exact error trace you're getting.
Copy paste from console.
That error will often tell you exactly where you're issue is, and exactly what it is.
Offline PwndKilled
« Reply #2 on: January 24, 2015, 12:02:43 pm »
PwndKilled|2|STEAM_0:0:0000000
[ERROR] addons/ulx/lua/ulx/modules/sh/freezeplayers.lua:38: attempt to call method 'Freeze' (a nil value)
  1. fn - addons/ulx/lua/ulx/modules/sh/freezeplayers.lua:38
   2. unknown - addons/anticheat/lua/_ley_imp.lua:973
« Reply #3 on: January 24, 2015, 04:44:30 pm »
My educated guesses, from greatest to least likely reason it's not working.
From http://wiki.garrysmod.com/page/Player/Freeze ....
1) Freeze is server side only... you're running in a 'shared' module, and throwing a client side error because the client side doesn't know what "Freeze" is.
OR
2) Freeze is player entity only...Your if statement at line 13 checks "is ent a player?", in addition to group checks. If not a player or not a group match, it runs that command at line 38. If you run Freeze on a non player entity, it might error out.
OR
3) LEAST likely - something in your anti-cheat is causing Freeze to be nil. (Again, LEAST LIKELY... we get blamed for much because our hook system often appears in an error trace...so I'm not likely to blame the anticheat just because it's at the bottom of the trace.
Offline PwndKilled
« Reply #4 on: January 28, 2015, 06:21:58 pm »
i removed the anticheat how do i fix this annoying error
« Reply #5 on: January 28, 2015, 08:27:57 pm »
As I stated, #3 was least likely the issue.
1) Don't run the freeze command on client.
2) Don't run the freeze command on a non-player object.
Offline PwndKilled
« Reply #6 on: January 30, 2015, 11:40:36 pm »
I'm not a lua coder so i don't really know how to fix it
« Reply #7 on: January 31, 2015, 08:46:32 am »
I was under the impression you had made it and just wanted help fixing it.
Where did you get the code from?
Perhaps the original developer has newer/corrected code?
Offline PwndKilled
« Reply #8 on: January 31, 2015, 06:25:00 pm »
Offline PwndKilled
« Reply #9 on: February 12, 2015, 02:56:43 am »
bump
