Author Topic: (Someone) has slayed You and etc.  (Read 6683 times)
Offline Unknown Gamer
    • TrueKnife TTT
« on: March 31, 2015, 10:07:16 am »
Hi,
So people have been saying instead of seeing Unknown Gamer has slayed You, they see (Someone) has slayed You. How do I make it show my name. It makes it hard for someone to report an abusing admin on the server. And in general just annoying. How do I make it show teh person running the command?
Newb Coder. Soon to get better
Re: (Someone) has slayed You and etc.
« Reply #1 on: March 31, 2015, 10:17:31 am »
XGUI>Settings>Server>Log Echo(or something along those lines)>read given info
The search box exists for a reason. Please use it.
Offline XxLMM13xX
  • New to lua development
    • Twitch
« Reply #2 on: March 31, 2015, 10:26:53 am »
Hi,
The reason they see this is because of hidden echos...
to fix this you need to do the following...
type !menu in chat to bring up the menu>goto groups>user>manage permissions>other>then check "ulx seeanonymousechoes" this should fix it
EDIT: Looks like Bytewave has beaten me to it while i was typing... both ways should work!
Offline Buzzkill
    • The Hundred Acre Bloodbath
« Reply #3 on: March 31, 2015, 07:46:47 pm »
Kinda.
ulx logecho = 0 prevents admin commands from being echoed at all.  Setting ulx logecho to 1 shows them anonymously, and ulx logecho 2 shows the source of the command.
"ulx seeanonymousecho" permissions controls who gets to see the source of a ulx command even when they are purposely issued anonymously (ie, when ulx logecho is 1).  This is intended as seconday, fine-grained echo control  (ie, admins can see which op issues a gag, but users see it anonymously).
Unless you want to create a tiered approach to echoing, I would recommend ulx logecho = 2.
« Reply #4 on: March 31, 2015, 07:54:59 pm »
