Author Topic: Rank Changing Lag  (Read 12379 times)
Offline Zaddion
Rank Changing Lag
« on: April 02, 2015, 04:45:06 pm »
So this is a bug on my server that I haven't been able to figure out how to fix. I've talked to many people about it and I've tried removing things that could possibly interfere with the rank changing. I have reinstalled ulx completely and I still have this issue. When I change someones ulx rank, the server lags (everyone) for like 2-3 seconds. The only thing anyone can come up with is the large user file, but how would I make the users data file smaller without everyone losing their ranks? The current size is 392kb, (401,408 bytes).
Offline Zaddion
Re: Rank Changing Lag
« Reply #1 on: April 02, 2015, 04:51:24 pm »
Someone suggested using SQL to store ranks, anyone know of a good ulx sql database addon?
Offline XxLMM13xX
  • New to lua development
    • Twitch
« Reply #2 on: April 02, 2015, 05:02:41 pm »
Are you sure it happens to EVERYONE? It may be a client side thing with you...
Also, if your running a lot of HUGE addons at the same time this could happen. im not good with MySQL so i have no idea. What gamemode are you running? I have never had/seen this problem
Offline Zaddion
« Reply #3 on: April 02, 2015, 05:13:29 pm »
It happens with everyone, every player freezes for 2-3 seconds.
« Reply #4 on: April 03, 2015, 01:47:41 am »
Zaddion, are you using some kind of addon that auto promotes players out of the standard 'user' group?
ULX (or more accurately ULib) wasn't designed to store authentication details for every player who joins your server. As an Admin mod, the current system is really only meant to store data for administrators and maybe VIP or donator groups. When you start trying to Auth every player it can really inflate the file and when garrysmod goes to open and seek information from that flat file, it will cause your server to lock while it's doing that.
The only fix, really, is to trade up the standard flat file system for an SQL based system.
If you search for it, you'll find a couple snips of code that people have released (myself included) that will help you convert your ULX installation to use SQL.
This will require some basic knowledge and access to the root of your gmod installation (to install the SQL module which is a dll file) as well as access to a MySQL database (preferably on the same physical system as your game server).
Offline Zaddion
« Reply #5 on: April 03, 2015, 12:02:23 pm »
Thank you for responding, MrPresident. Yeah, I'm using ulx autopromote. Can you possibly link me to an SQL system for ULX? I have past experience with SQL and some other addons of mine use SQL so it shouldn't be a big problem to convert.
« Reply #6 on: April 03, 2015, 08:38:05 pm »
ulx autopromote
*cringe*
I'm starting to really dislike how people seem to want to use that release.
As MrPresident states, Gmod's way of storing admins, and the enhanced but same flat file way ULib does, was never meant to store so many.
400K? Sheesh that's a lot of users.
I've nothing against SQL mind you. We plan to one day go there for modernization and enhancement sake.
The primary reason though is not to increase the potential amount of admins, but to make multi-server configs easier.
« Reply #7 on: April 03, 2015, 08:44:27 pm »
This post prompted me to do this: /index.php/topic,8377.0.html
This is by far the most seamless integration of MySQL into ULib that I've done so far.
« Reply #8 on: April 03, 2015, 09:02:32 pm »
* 3 quick pat on back "man" hug* I love you *pat pat pat release back away 3 steps*
« Reply #9 on: April 03, 2015, 09:14:53 pm »
Figure I gotta do *something* around here to earn my keep.
« Reply #10 on: April 03, 2015, 09:20:59 pm »
*drools* I suggested the SQL, but I was not expecting you to come out with it that quickly.  Had it in the works for a bit?  haha
Offline Zaddion
« Reply #11 on: April 03, 2015, 10:12:08 pm »
Thank you so much!
« Reply #12 on: April 03, 2015, 10:28:34 pm »
... Had it in the works for a bit?  haha
Nope. I started work on it after I saw this post today at like 2pm or so.
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
« Reply #13 on: April 03, 2015, 10:41:18 pm »
just wanted to say, TL:DR anything above.
I once tried to rewrite ulx in a database format, but I didn't feel like finding out how they structure their data for ulx ranks. Too much work, so gave up, and yeah.
