Author Topic: Changes not saving  (Read 21559 times)
Offline jdrayner2
Re: Changes not saving
« Reply #15 on: April 14, 2015, 10:23:40 am »
If your changes aren't saving, double check to make sure the server has write permissions to the data folder.
Yes it does have full permissions to the data folder
Offline jdrayner2
« Reply #16 on: April 14, 2015, 03:55:05 pm »
banning saves.... its just when you go to unban people they will be un banned but as soon a reboot Boom Banned again
« Reply #17 on: April 14, 2015, 07:58:35 pm »
Sounds like you have another addon/gamemode conflict or exploited code somewhere.
Offline jdrayner2
« Reply #18 on: April 15, 2015, 01:01:49 am »
i looked in the bans file and i could not find my steamid in the bans.txt
i have also looked in the banned_user.cfg and my steamid is not there but as soon as i reboot boom banned but still not in bans.txt
Offline Buzzkill
    • The Hundred Acre Bloodbath
« Reply #19 on: April 15, 2015, 05:37:03 am »
This topic seems to be getting highly fractured.  The OP stated that bans weren't saving, but then contradicted later on, saying that bans were fine but unbans weren't saving.  Others have added variations (groups, custom groups, etc) that may or may not have anything to do with the OP.
FWIW, I can confirm that I run multiple custom groups and have no issue with ban, unban or group membership persistence. This is with the latest repo version of everything. (ULX, ULib, etc). I realize that doesn't magically fix everything for everyone -- but I do want to put it out there that it does work as expected, at least under some environments.
To clarify, the /data/ulx/bans.txt file is simply a history of ban activity that contains a bit more metadata than the stock banned_user.cfg file -- it doesn't directly affect ban status for individuals.  That status comes from /cfg/banned_user.cfg.  If ban or unban status is not "sticking" between map changes or restarts then I would suggest that a "wriiteid" con command is not being issued after the adjustment.  "writeid" flushes the in-memory ban list to banned_user.cfg.  Any time I've had problems with bans not persisting, it's because I was using a mechanism (some other addon, code of my own, etc) that was creating the ban/unban but then NOT issuing a "writeid".
HTH
« Last Edit: April 15, 2015, 05:39:16 am by Buzzkill »
Offline jdrayner2
« Reply #20 on: April 19, 2015, 01:30:46 pm »
this is what i see in the console after a reboot.
Client "jdrayner2" connected (IP REMOVED).
Writing cfg/banned_user.cfg.
then Boom im banned
Offline jdrayner2
« Reply #21 on: April 19, 2015, 01:52:22 pm »
what i dont understand is why it instantly starts Writing cfg/banned_user.cfg
there was no other people online when i connected
Offline jdrayner2
« Reply #22 on: April 21, 2015, 01:31:39 pm »
Hello
Offline jdrayner2
« Reply #23 on: April 21, 2015, 02:55:40 pm »
the issue has now got bigger i can no longer connect to the server as i get banned as soon as i am spawned
ServerLog: jdrayner2 (STEAM_0:0:55556182) Disconnected
Dropped jdrayner2 from server (Kicked and banned)
no players are online when this happens
« Reply #24 on: April 21, 2015, 05:11:33 pm »
Remove your addons one by one to figure out what's banning you.
Offline jdrayner2
« Reply #25 on: April 21, 2015, 05:38:52 pm »
Yeah your right, I removed all my workshop addons and non-workshop addons then
i installed only ulx and ulib and boom no more auto-bans
i will be slowly adding 1 at a time (long and boring process) but it will pay off once i am done
Offline jdrayner2
« Reply #26 on: April 21, 2015, 05:41:29 pm »
Okay its something in darkrpmodification-master
i think i may have a bad copy or something
Do you have a download link to one?
« Reply #27 on: April 21, 2015, 06:18:38 pm »
That's likely a download of DarkRP from their Github repository- should be able to get the latest version from there:
https://github.com/FPtje/darkrpmodification
