Author Topic: Can't physgun players props.  (Read 11857 times)
Offline DumStriker33
« on: May 26, 2015, 09:28:53 am »
I have been made a Moderator on a server, All other mods on the server can move,remove players props. But for some odd reason i can't.. Owner tried to fix it but he said that he thinks there is no way around it and i would like to ask if there is anyway for me to actually physgun,remove other player's props, if there is a fix for it or anything?
Thank you, DumStriker
Offline Caustic Soda-Senpai
    • Steam Page
Re: Can't physgun players props.
« Reply #1 on: May 26, 2015, 09:57:40 am »
It would be in the server's permissions which the owner of your server sets up. If other players in your same exact group can do what you can't, check your XGUI Client Settings. I believe there's an option for the ability of physgunning objects/players; make sure that's enabled.
EDIT: Is the gamemode DarkRP?
« Reply #2 on: May 26, 2015, 11:34:28 am »
Hi, Thank you for reply, it is a DarkRP server, yes. And in the XGUI it only allowed me to physgun players option.
    • Steam Page
« Reply #3 on: May 26, 2015, 01:09:43 pm »
Tell the owner to disable FAdmin, this is the root cause of many problems if both ULX and FAdmin are installed on the same server.
FAdmin and ULX are like angry neighbours, they hate each other.
If you need to disable it, refer to /index.php/topic,7886.0.html#msg40096 />
If the error persists, it's a permission issue that the Owner has set up. Prop Protection most likely.
« Reply #4 on: May 26, 2015, 01:49:22 pm »
But if all other mods/admins can move props and i can't does that mean that he has to disable FAdmin still?
« Reply #5 on: May 26, 2015, 03:52:35 pm »
ULX has no prop protection included of any sort.
It's difficult for us to tell what your issue is.
If ULX isn't seeing you as the group needed for prop control, and you are indeed 100% certain you're a member of the required group, then it is likely a conflict in another addon or gamemode.
