Author Topic: E2 Wirelink  (Read 6240 times)
Offline SSJ2 Vegeta
E2 Wirelink
« on: June 06, 2015, 06:09:12 pm »
hello, i run a sandbox server named Planet Vegeta Build, and my E2 system isnt working. as in i have a drone that you have to say !on to turn it on, and it will not work, same with the wirelink system doesnt work either. it is only broken with anything with an E2 wiring.
Offline XxLMM13xX
  • New to lua development
    • Twitch
Re: E2 Wirelink
« Reply #1 on: June 07, 2015, 06:27:32 am »
Re wire it... also maybe the codes not right... Post the code here!
Offline SSJ2 Vegeta
Re: E2 Wirelink
« Reply #2 on: June 08, 2015, 07:34:32 pm »
oh its not the drone, it worked fine before. the E2 Wirelink system on my server is broken. i can take the drone to another server and it works fine, but i bring it to my server and anything that is Wirelinked with E2 doesnt work. everything else E2 works fine, but the E2 wirelink system doesnt work
Offline SSJ2 Vegeta
Re: E2 Wirelink
« Reply #3 on: June 12, 2015, 04:24:11 pm »
so i guess no one has any idea then. well i guess i cant use wiremod adymore then
