Author Topic: little chat command help  (Read 7940 times)
Offline XxLMM13xX
  • New to lua development
    • Twitch
« on: August 28, 2015, 06:44:28 pm »
Alright so right now i'm making a new chat command to set a persons bail... now this is the command:
!setbail xxlmm 100
Now i have this var:
jailer = text[2] (Yes this is all set up with the explode thing)
so how do i take the string and turn it to a player entity??
Thanks!
Re: little chat command help
« Reply #1 on: August 28, 2015, 06:48:54 pm »
You could make it run through ULX and it would be so much easier, but if you don't want to...
You have to use player.GetAll().  Put that in a for loop and check each player instance to see if the string matches any part of the name.
Offline XxLMM13xX
    • Twitch
« Reply #2 on: August 28, 2015, 06:51:54 pm »
Thats what i was thinking but if the player does xxlmm instead of my FULL name then what do i do? How do i call a part of the players name??
« Reply #3 on: August 28, 2015, 06:53:56 pm »
Offline XxLMM13xX
    • Twitch
« Reply #4 on: August 28, 2015, 06:55:38 pm »
I'm confused, didn't you make this already?
im trying to make this branch off from ulx to add support for others/non ulx users/losers (BECAUSE ULX IS GOD OF GMOD)
Anyway im also remaking a bail npc to hopefully release on scriptfodder to beat the current broken one!
« Reply #5 on: August 28, 2015, 06:56:43 pm »
As for how, you'd have to use string.find within GetAll loop for value:Nick() (or :Name(), I always forget))
« Reply #6 on: August 28, 2015, 07:01:17 pm »
I just got ninja'd by like 3 posts.
Exactly what I was about to say.  And Nick() and Name() are the same function.  Garry literally just copied the functions over to each other.
