Author Topic: How to make it so freeze is disabled if being whipped?  (Read 4537 times)
Offline JohnnyAppleseed
« on: October 24, 2015, 11:18:29 am »
Hello everyone! I run a darkrp server, and I would like to figure out how to make it so that if a player is being whipped, they can't be frozen?
if v.whipped then
ULib.tsayError( calling_ply, v:Nick() .. " is being whipped!", true )
v:Unlock()
v.frozen = nil
ulx.clearExclusive( v )
that's what we've tried. But it doesn't work!
Offline WispySkies
Offline WispySkies
Re: How to make it so freeze is disabled if being whipped?
« Reply #2 on: October 27, 2015, 03:27:13 pm »
Just tested it, but its not right, and it is all that I could think of atm >_> Sorry.
Offline roastchicken
  • I write code
« Reply #3 on: October 29, 2015, 08:13:25 am »
I'm not sure where you guys are putting that code, but you're going to need to modify the freeze command itself. Just put a check at the top for v.whipped and print a message and return to prevent them from being frozen. It's not a good idea to overwrite the default ULX files because any changes will be lost when you update, so instead you should make a separate addon with a duplicate of the freeze command with your custom changes.
