Author Topic: UBan -- Global ban system. Ban users from all servers connected to a single DB!  (Read 168331 times)
It's trying to tell you that you don't have it installed correctly.
Offline Buggzie
accept my friend invite on steam and help me out then, I'm sure ive tried installing it properly.
I'll be on steam in about twelve hours.
Offline Buggzie
I'll be in bed by then...
just accept eyefinity and i'll contact you when im online the same time as you.
Offline Buggzie
When MySQL Server has gone away because of wait_timeout running out. The persistent connection dies and it spams that the MySQL Server has gone away...
It doesn't even attempt to reconnect
Buggzie, I really think your SQL host is bad. It shouldn't lag so much, you shouldn't need persistent connections that you keep asking for in every SQL release.
Something is wrong, and it's not all of the SQL releases here.
Offline Buggzie
1) Crappy host
2) Non-local MySQL Connection
3) gm_mysql
nuffsaid
Offline D3vine
« Reply #142 on: August 23, 2010, 05:37:33 pm »
] ulx gban vinny 1
Invalid command entered. If you need help, please type "ulx help" in your console.
any help please?
Are you running the SVN-able one from the previous page?
Offline D3vine
Not sure, I have my server GSP set it up. I'll try installing the svn.
Offline jdmmer
How do I change the access from superadmin to admin?
Same way you allow any command. ulx groupallow <group> "ulx <command>"
Or if on game client, XGUI is the easiest.
Offline uubucks
i am having some trouble aswell. i used UBan before. Im pritty good with mysql in and out of gmod and ive setup the DB and everything correctly and put in both the one on the original post and the one on the page before. neither load. no errors being output. i am running the SVN version (latest) of ULX and ULIB. Put the uban in the addons and also tried intigrating it directly into both Ulib and ULX. Any help?
Run "path" in server console and post the output here.
Offline uubucks
This is just with ULX and Ulib and some other addons installed. will repost when i put my gamemode and map on.
Paths:
"maps\gm_flatgrass.bsp" "GAME" (map)
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\bin\" "EXECUTABLE_PATH"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\platform\" "PLATFORM"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\" "MOD"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\bin\" "GAMEBIN"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\hl2\bin\" "GAMEBIN"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\hl2\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\" "DEFAULT_WRITE_PATH"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\" "LOGDIR"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\hl2\" "hl2"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\toybox\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\cstrike\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\cstrike\" "cstrike"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\dod\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\dod\" "dod"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\ep2\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\ep2\" "ep2"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\tf\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\tf\" "tf"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\episodic\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\episodic\" "episodic"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\hl2mp\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\hl2mp\" "hl2mp"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\portal\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\portal\" "portal"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\lostcoast\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\lostcoast\" "lostcoast"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\counter-strike\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\day-of-defeat\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\hl2_ep2\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\portal\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\tf2\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\adv duplicator\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\colonies-improved\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\css realistic weapons 4.0\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\deathmessages\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\easyprecision\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\enhanced citizens\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\faphack\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\freespace_revolution\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\keypad\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\keypad cracker\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\keypadcracker\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\ocrp%20content\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\perfected climb swep\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\permaprops\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\sicknessmodel\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\smartsnap\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\spiderman's_swep\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\stacker stool\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\umb weapons\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\voiceradio\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\weathermod v7\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\wire\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\wire model pack 1\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\wire%20model%20pack%201\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\wiremodextras\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\gamemodes\ascension\content\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\gamemodes\dogfightarcade\content\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\gamemodes\prop_hunt\content\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\gamemodes\sandbox\content\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\gamemodes\terrortown\content\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\gamemodes\colarp\content\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\gamemodes\darkrp\content\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\gamemodes\gcraft\content\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\gamemodes\perp\content\" "GAME"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\platform\config\" "CONFIG"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\lua\" "LuaMenu"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\gamemodes\" "LuaMenu"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\lua_temp\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\lua_temp\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\gamemodes\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\counter-strike\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\day-of-defeat\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\hl2_ep2\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\adv duplicator\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\colonies-improved\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\css realistic weapons 4.0\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\deathmessages\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\easyprecision\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\faphack\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\keypad\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\keypad cracker\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\keypadcracker\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\perfected climb swep\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\permaprops\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\sicknessmodel\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\smartsnap\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\spiderman's_swep\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\stacker stool\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\umb weapons\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\voiceradio\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\weathermod v7\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\wire\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\wiremodextras\lua\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\gamemodes\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\counter-strike\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\day-of-defeat\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\hl2_ep2\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\adv duplicator\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\colonies-improved\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\css realistic weapons 4.0\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\deathmessages\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\easyprecision\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\faphack\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\keypad\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\keypad cracker\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\keypadcracker\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\perfected climb swep\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\permaprops\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\sicknessmodel\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\smartsnap\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\spiderman's_swep\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\stacker stool\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\umb weapons\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\voiceradio\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\weathermod v7\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\wire\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\addons\wiremodextras\lua\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\gamemodes\base\entities\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\gamemodes\base\entities\" "lua_ufolded"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\gamemodes\sandbox\entities\" "lua_cient"
"c:\program files (x86)\steam\steamapps\-snip-\garrysmod\garrysmod\gamemodes\sandbox\entities\" "lua_ufolded"
« Last Edit: January 27, 2011, 03:19:11 pm by uubucks »
