Author Topic: UBan -- Global ban system. Ban users from all servers connected to a single DB!  (Read 168331 times)
Alright, try this out and let me know if it works with current ULX release: Download
Offline blackfire88
here's a hint, make it say the reason, instead of "Banned on the global ban list"
If you give a reason, it states the reason.
Offline blackfire88
allright, it doesnt work. :( it says Gban failed.
ulx gbanid STEAM_0:0:22318105 0
UBan failure. Error is: [addons\uban\lua\autorun\server\uban.lua:64] attempt to index global 'mysql' (a nil value)
Global ban failed! See server console for error.
And what did server console say?
Offline blackfire88
that IS the error isnt it? The lua one? I'll just go look in console then if you want.
Looks like you don't have the MySQL module installed. That's required for this addon to function.
Offline blackfire88
I do have it installed :3
Which one do you mean? The one on your first post or the new one?
I put all the files in the right place. Libmysql.dll and everything.
Are you installing this on a dedicated server or listen server?
Offline blackfire88
dedicated.
On a dedicated server, one of the .dlls has to go into the same folder as srcds.exe is in, under the orangebox folder I believe.
Offline blackfire88
That module is incompatible, unfortunately.
Offline blackfire88
so i have to use the old module?
The one that doesnt work? :'(
Offline blackfire88
Wait, do i install ALL the modules? Or just like, there is a windows one and a linux one?
