« on: July 19, 2007, 10:08:43 pm »
What is it?
Uclip is a noclip alternative. By this we mean it's similar but different in the fact that you can't noclip through anything but your own props (If you're running a prop protection). So, you can't noclip through the world or through others' props. Admins can still noclip through everything.
Prop protectors supported: (if you don't have one of these everyone can noclip through every prop)
* UPS (recommended!)
* Simple Prop Protection
* FPP
* Anything else that uses CPPI (contact the mod author)
Video:
This video demonstrates noclipping up to a player's prop (handles odd angles okay), noclipping up to the ground, then noclipping through a tight space by "ducking".
Known bugs:
* If you're noclipped, people can move props inside of you. You'll then be able to noclip through their prop in order to get out. Better than getting stuck though, right?
Special thanks:
* Ryno-SauruS - Figuring out a workaround for garry's noclip bug.
* Spbogie: Helping me think of different ways to accomplish this, writing the initial version.
* Banyon: Bug testing.
* DrogenViech: Finding +moveup/+movedown exploit.
Download:
http://ulyssesmod.net/archive/Uclip/Uclip-v1_22.zip
« Last Edit: January 27, 2013, 07:36:41 pm by Megiddo »
Offline Chironex
  • Formerly known as Kyzer
Re: Uclip -- A noclip alternernative!
« Reply #1 on: July 20, 2007, 04:40:08 pm »
Interesting  :o
I will try it, thanks.
edit:
Here is my config, i use PropProtection and i would like to test this noclip protection but i'm an admin;
-- Config
local function adminCheck( ply ) -- Who can move through everything? Comment out these lines for no one.
//if ulx and ply:query( "ulx noclip" ) then
// return true
//elseif ply:IsAdmin() or ply:IsSuperAdmin() then
// return true
//end
return false
-- End config
local hasPropProtection = true -- Chaussette's Prop Protection (preferred over PropSecure)
local propProtectionFn -- Function to call to see if a prop belongs to a player. We have to fetch it from a local so we'll store it here.
local hasPropSecure = false -- Prop Secure by Conna
local hasProtector = false -- Protector by Conna
local noProtection = false -- If there's no protection whatsoever, this is flagged.
As you can see i disable the admincheck. But it doesn't do anything, i mean as an admin i can still move outside world and inside players props. Also the function admincheck is never used in the script, and i can't find the word 'admin' in another place on this script. Strange :o
How can i test it without changing my group etc ?
For future update (if any but i guess yes), i would like to see a menu, like just below PropProtection's control panel, with some options like:
admins functions:
toggle on/off
admins can noclip everything (on/off)
functions for all:
a list of players that we can choose to be allowed to noclip our prop, like, if player1 is not allowed and player2 is allowed:
Player1 [allow]
Player2 [disallow]
well..i'm sure you know what i mean X)
They are just suggestions i would like to see!
REEDIT: error report!
Warning: Unhandled usermessage '[STRING NOT POOLED]'
ERROR: Hook 'UclipMove' Failed: ULib/_cl_2.05/sh_ucl.lua:19: attempt to call method 'IsListenServerHost' (a nil value)
Removing Hook 'UclipMove'
« Last Edit: July 20, 2007, 06:25:57 pm by Kyzer »
« Reply #2 on: July 20, 2007, 07:43:17 pm »
Kyzer. Nice thoughts.
However, I've not tested this yet, but would hope that the various prop protects allow player sharing. If the prop protect allows a player to touch, then wouldn't this allow the player to also noclip?
This would make the 'player' portion of your menu idea redundant. :)
adamscybot
« Reply #3 on: July 22, 2007, 03:26:31 am »
Can this script be modified so SuperAdmins can go through everything (as they do now) but admins cant go through the World, SuperAdmins props, or other normal admins props (so basically they can only go through normal users props). I use Uteam too.
I use PropProtection.
Offline truck
« Reply #4 on: July 25, 2007, 09:57:54 am »
How i use this script??
I put TRUE after prop protection
« Reply #5 on: July 25, 2007, 02:37:36 pm »
Sorry, guess I should've been clear in the comments. Those flags are all set by the script itself, you shouldn't (read: DON'T!) set those yourself.
Offline truck
« Reply #6 on: July 26, 2007, 08:59:25 am »
I get the same error of Kyzer
You can fix this error??? Because nobody can use noclip perfectly. Collision work but nobody can move when he flying
Thx
« Reply #7 on: July 26, 2007, 12:57:21 pm »
Try changing this:
-- Config
return true
return true
return false
-- End config
To this:
-- Config
return true
return false
-- End config
See if that works or not.
Offline truck
« Reply #8 on: July 26, 2007, 05:55:28 pm »
ok finaly your script work before your new solution.... Your new solution is for remove the error in the console???
Offline truck
« Reply #9 on: July 26, 2007, 06:08:55 pm »
I get error again with your new solution
EDIT: How i remove the right of the admin for flying??? Because admin can go anywhere and i want to remove that
thx
« Last Edit: July 26, 2007, 06:13:42 pm by truck »
« Reply #10 on: July 26, 2007, 06:51:14 pm »
In that case replace that chunk of code with this:
-- Config
return false
-- End config
Offline truck
« Reply #11 on: July 26, 2007, 09:16:53 pm »
i need your help to change color of my scoreboard... I try but its hard. I find how to change the logo and hostname color but im not sure i do it properly
You can explain me please
thx
« Reply #12 on: July 26, 2007, 10:13:10 pm »
Stay on topic please.
Offline truck
« Reply #13 on: July 26, 2007, 10:20:16 pm »
ok.... Your code doesnt work... I can pass in all thing
Other solution???
Explain how for color by PM... thx
« Reply #14 on: July 26, 2007, 11:35:35 pm »
Are you still able to go through the world, or only props?
