Re: Uclip -- A noclip alternernative!
« Reply #30 on: July 31, 2007, 04:21:38 pm »
Ok.... Do you try with Vehicule All in one??
Never heard of it.
Offline truck
« Reply #31 on: July 31, 2007, 04:47:16 pm »
Its the biggest vehicule pack on facepunch. Almost all server have this pack
I just know about server crash with vehicule but i dont know if that about new or orignal vehicule...
I give you the link of this vehicule pack... You can test to enter in this vehicule without admin
http://forums.facepunchstudios.com/showthread.php?t=262843&highlight=gmow
« Reply #32 on: July 31, 2007, 04:50:32 pm »
It can't be used on too many servers if I've never heard of it :P
I think I'll just stick to GMow and PHX.
I tried the airboat seat from GMow and it crashed, so I guess it's only on custom vehicles.
You can fix by adding:
if ply:InVehicle() then return end
after:
if GetConVarNumber( "sbox_noclip" ) == 2 or ply:query( "ulx noclip" ) then return end -- They can go through everything
Offline truck
« Reply #33 on: July 31, 2007, 05:13:28 pm »
Yeah custom vehicule :P
vehicul All in one contain Gmow ^^
Do you tried your code??? If is working.... Put him in your futur version ^^
And you have solution for put flying for admin too???
Offline truck
« Reply #34 on: August 03, 2007, 04:52:54 pm »
you remove my UP but you dont answer....
[edit JamminR - removed foul language IM abbreviation - this is a family oriented forum for all ages. Don't go there]
« Last Edit: August 03, 2007, 06:04:07 pm by JamminR »
Offline atomicspark
« Reply #35 on: August 03, 2007, 05:25:02 pm »
Megiddo is on vacation. He'll be back soon.
« Reply #36 on: August 03, 2007, 06:02:58 pm »
you remove my UP but you dont answer.... wtf
Truck...chill.
As atomicspark said, Megiddo is unavailable.
Bumping a thread on any forum isn't nice.
It's rude. So I removed it.
« Last Edit: August 03, 2007, 06:04:32 pm by JamminR »
Offline truck
« Reply #37 on: August 03, 2007, 07:30:27 pm »
Its ok ^^
Offline truck
« Reply #38 on: August 06, 2007, 06:36:05 pm »
megiddo is back ahah
Offline EscudoDenali
« Reply #39 on: August 06, 2007, 11:08:16 pm »
Hey, I'd like to report that when I first start my server which has UClip on it, I get server spam for 72,465 lines, then says this:
SERVER: ERROR: Hook 'UclipMove' Failed: autorun/uclip.lua:170: Infinite Loop Detected!
SERVER: Removing Hook 'UclipMove'
"What I lack in skill, I make up for in stupidity." - EscudoDenali
Escudo's Non-Tolerance Server <--- FUN
« Reply #40 on: August 07, 2007, 11:28:47 pm »
New version (1.0) up! Changes:
Changes:
* Implemented fail safes so it can't get in any infinite loops (no such problem has been reported, just being safe)
* Minimized check distance so you don't stop a ways away from a wall.
* Split it up into shared, server, and client files (easy for me to understand that way)
* Revamped how it detects if you're stuck, there was an exploit to get through props with the old method.
* Fixed the admin check.
* Added specific checks for when players wedge themselves into tight areas. It was processing their velocity to 0 in this case before (not a horrible bug, so this is really just optimization).
* Added a vehicle check (apparently old version could crash if you were noclipped and entered a custom vehicle)
Make sure you delete the old version FIRST!
Offline Chironex
  • Formerly known as Kyzer
« Reply #41 on: August 08, 2007, 12:01:49 am »
* Testing *
Thanks for your work :)
Will you release a new ulx soon ?
Edit; just saw the svn thing, i'll try that too! And Prop protection is still not fixed :(
« Last Edit: August 08, 2007, 12:07:37 am by Kyzer »
Offline Chironex
« Reply #42 on: August 12, 2007, 03:20:25 pm »
I have a problem with this script, it happen when i press my noclip key (MAYBE while i'm under world)
ERROR: Hook 'UclipMove' Failed: ULib/_cl_2.05/sh_ucl.lua:19: attempt to call method 'IsListenServerHost' (a nil value)
Can you tell me how to solve that. I'll remove addons to see if this is caused by another addon.
« Last Edit: August 12, 2007, 03:22:15 pm by Kyzer »
« Reply #43 on: August 12, 2007, 03:28:58 pm »
Kyzer,
 We didn't make prop protection.
Chausette did.
Offline Chironex
« Reply #44 on: August 12, 2007, 03:57:05 pm »
Yes i know :p..i'm just annoyed that its still not fixed and that i can't fix it by myself. I'm writing my own -simple- prop protection anyway.
