Re: Uclip -- A noclip alternernative!
« Reply #45 on: August 12, 2007, 05:12:57 pm »
It's actually a bug from the current release version of ULib. I'll make a patch for Uclip to detect it as soon as I can.
Offline truck
« Reply #46 on: August 25, 2007, 02:56:14 pm »
with you new release... i can remove admin right?? I want to put fly on admin too
thx
« Reply #47 on: August 27, 2007, 11:53:12 am »
New version up!
Changes:
   * [ADD] Support for EPS and Simple Prop Protection
   * [FIX] Now treats all prop_dynamic's like a wall. This means you won't be able to go through any door made by door mod. (Sorry! Gmod problem forced our hand.)
Let me know if any of you are still getting crashes from Uclip now. Thanks!
Offline Chironex
  • Formerly known as Kyzer
« Reply #48 on: August 27, 2007, 12:04:04 pm »
I will test it thanks, oh and you made a mistake in the download name, need a 'c' instead of 'C'
 V
« Last Edit: August 27, 2007, 12:15:36 pm by Kyzer »
« Reply #49 on: August 27, 2007, 12:12:34 pm »
Thanks Kyzer. You sort of start losing your mind after so many releases when you post them to two places. :P
Offline truck
« Reply #50 on: August 27, 2007, 04:31:38 pm »
hello???
How i can put admin flying??? Because admin can pass in the wall
« Reply #51 on: August 27, 2007, 04:40:29 pm »
Truck,
Sorry, but we do not understand you.
Admins are supposed to be able to fly through walls. UClip was written to let admins do this.
Offline truck
« Reply #52 on: August 27, 2007, 05:06:56 pm »
I want to remove the right of the admin on UCLIP. Now... Admin can pass in the wall. I want to remove that
« Last Edit: August 27, 2007, 05:09:59 pm by truck »
Offline truck
« Reply #53 on: September 02, 2007, 10:41:38 pm »
Hey answer please???
(ban me if you want....anyway, you never answer at my questions... retard)
Offline spbogie
« Reply #54 on: September 03, 2007, 06:25:00 am »
Quote from: Megiddo
New version (1.0) up! Changes:
Changes:
* Implemented fail safes so it can't get in any infinite loops (no such problem has been reported, just being safe)
* Minimized check distance so you don't stop a ways away from a wall.
* Split it up into shared, server, and client files (easy for me to understand that way)
* Revamped how it detects if you're stuck, there was an exploit to get through props with the old method.
* Fixed the admin check.
* Added specific checks for when players wedge themselves into tight areas. It was processing their velocity to 0 in this case before (not a horrible bug, so this is really just optimization).
* Added a vehicle check (apparently old version could crash if you were noclipped and entered a custom vehicle)
You were given your solution earlier, and it didn't work because Meg forgot to include the admin check. Had you been paying attention you would have seen that this was fixed and the solution given to you would now work correctly.
« Reply #55 on: September 03, 2007, 06:26:27 am »
If you had done any research at all you would know the answer to your question truck. Oh well, it's too late for that now; enjoy the permaban.
redtrigger
« Reply #56 on: September 13, 2007, 01:57:18 am »
I understand you truck. This guys never answer on this forum
« Reply #57 on: September 13, 2007, 05:51:12 am »
Truck, we knew it was you posting as redtrigger with a new IP from the first time you posted. We were content to just let you have it... but that was just overdoing it.
« Reply #58 on: September 13, 2007, 02:12:32 pm »
Totally Off topic post.
He's part of the sympatico.ca domain.
I remember channel banning the entire domain for weeks, sometimes months, at a time back in early 90s when I was an IRC channel op, and often got the Server admins to K-line too.
Though the channel ban offenses were usually just not following rules, the Klines came along with the flood bot nets.
I was hoping it was a small faction. Seems to me though, me stereotyping here, that perhaps majority rules the sympatico domain.
Ahh. My good ol' days.
Now, back to UClip. Seems to work for me.
But, I'm an admin.
Offline Golden-Death
  • Honored Lua Scripter
    • BlueFire
« Reply #59 on: September 13, 2007, 03:13:56 pm »
Maybe you should just make a step by step help system like Windows. (Har, who ever thought any one would say that?)
Like:
Help I don't have access. (Next Page)
Is ULX properly running?
(Yes) (No)
Type ____ into the console. Do you see ____?
(Yes) (No)
Blah.
People are entertained when they get to click buttons. Not when reading a readme file.
So go give them some shiny red buttons.
Go on.
