Offline Ninjadude101
Re: Uclip v1.13 -- A noclip alternernative!
« Reply #75 on: April 26, 2008, 03:33:44 pm »
After installing UPS (which i now uninstalled due to an unexplainable problems.. it was just not working cant explain) This stopped working. i uninstalled it and reinstalled blablabla, but still this does not work.
The problem is basically that. Players can noclip as normal noclipping works.
In more detail here is the issue i had with UPS (i will also post this in UPS thread)
For some reason everything i spawned belonged to "Up for grabs!" and other people could not touch their own props, but could touch mine. If you rejoined, by typing retry in console, everything fixed. It was annoying me so i just deleted it for now.
« Reply #76 on: April 26, 2008, 04:24:36 pm »
As I said in the other thread, give us details. It works for everyone else using it, so obviously it's something you're doing wrong.
« Reply #77 on: April 26, 2008, 11:20:04 pm »
Edit by Megiddo: Tread lightly. Stop making trouble for us.
« Last Edit: April 27, 2008, 12:02:45 am by Megiddo »
Legend45
« Reply #78 on: May 06, 2008, 09:21:55 am »
Hi, when a server don't have Uclip, i go to the ground, and that lag much ! This is a bug ? Can you fix ? :)
Thanks ! ;)
Offline spbogie
« Reply #79 on: May 06, 2008, 12:32:50 pm »
« Reply #80 on: May 06, 2008, 03:23:13 pm »
Thanks ! ;)
My translation
Hi, when a server doesn't have noclip enabled, I sink into the ground, and it acts like I'm lagged
I believe this is a bug with maps compiled pre-TF2 engine. No, we can't fix it. It has nothing to do with UClip, as I've removed UClip and tested, and still sunk into the ground.
Freespace03, freespace06-v2-1 are notorious for this.
(I've also seen this explained as being due to Linux/Wine running Source dedicated server)
Legend45
« Reply #81 on: May 07, 2008, 04:41:23 am »
Sorry for my bad english, i'm french. :-\
But, with UCLIP, not when the server don't have sbox_noclip to 0 !
Example : A server don't have Uclip, but me, Uclip is on my addons. I join. I press v (noclip : on) i go to the ground and i lag very much !
1s for move..
Offline JokeAss
« Reply #82 on: June 09, 2008, 03:51:54 am »
Is there any SVN for this?
« Reply #83 on: June 09, 2008, 02:49:34 pm »
Yes, it's under the main repository just like every other project. :P
Offline Alex
« Reply #84 on: June 14, 2008, 12:40:10 pm »
Hi guys, I know NOTHING about LUA so could one of you post how the config looks like if want it admin can go through the world and other props thx.
:) Alex T. :)
« Reply #85 on: June 14, 2008, 12:45:09 pm »
That is the default behavior.
Offline Alex
« Reply #86 on: June 14, 2008, 01:06:27 pm »
Oh, :-[ ok thanks sorry to bother then.
:) Alex T. :)
Offline benbrooks
« Reply #87 on: July 12, 2008, 06:23:05 am »
I recently reinstalled my server and I put UPS on as well as uClip.
Unfourtunatley, UPS wasn't working at all, No idea why, So therefore uClip wasn't.
I removed both, Put Simple Prop Protection back on (What I had before I reinstalled) along with uClip.
SPP is working fine with protecting other peoples props, etc. but for some reason I can't get uClip working at all!  :-\
I've tried almost everything, I don't really want to switch prop protections as the SPP is working fine as it is.
Any help would be appriciated,
Thanks,
Ben
Offline Smoot178
« Reply #88 on: July 26, 2008, 11:38:10 am »
Yeah Uclip isn't working on my server at all either.
« Reply #89 on: July 26, 2008, 07:57:24 pm »
SPP does not support Uclip, though it will soon.
