minge
Re: Uclip -- A noclip alternernative!
« Reply #60 on: October 21, 2007, 04:19:16 pm »
the admin can move through everything with Simple Prop Protection when comment i removed :(
can you fix that please
« Reply #61 on: October 21, 2007, 10:10:30 pm »
What?
minge
« Reply #62 on: October 21, 2007, 10:33:09 pm »
I repeat,
In sh_uclip, you can allow or not admin pass through everything. That work perfectly with prop protection but that doesnt work with Simple prop protection.
Can you fix that??
« Reply #63 on: December 04, 2007, 03:22:34 pm »
I never was able to replicate minge's problem...
Anyways, new version out! Changes:
v1.11 - *(12/04/07)*
   * [CHANGE] Wall slide calculation is now much faster
   * [ADD] sbox_noclip 2 will now enables global "regular" noclip
« Last Edit: December 04, 2007, 04:25:51 pm by Megiddo »
Offline DrogenViech
Re: Uclip v1.1 -- A noclip alternernative!
« Reply #64 on: December 04, 2007, 03:58:07 pm »
I found a bug!
Bind a key to +moveup and another to +movedown.
Now stand on the ground, turn noclip on, and hold your +movedown key. :)
I think it's even possible to get through props with that... didn't tried yet.
« Reply #65 on: December 04, 2007, 04:08:04 pm »
Whoa, thank you DrogenViech! Major gratitude for telling us about this. I'll go work on a fix...
« Reply #66 on: December 04, 2007, 04:24:51 pm »
I realize how incredibly odd it is not to update for four months and then have two updates in one day, but an exploit was pointed out to me so here we go! New version, 1.12:
v1.12 - *(12/04/07)*
* [FIX] +moveup/+movedown exploit
Offline Dv2236
    • MyGamingVoid
Re: Uclip v1.12 -- A noclip alternernative!
« Reply #67 on: January 20, 2008, 06:45:29 pm »
i have try this addon 2 times now first time i did not notice anything but a error on side at first i did not know what it was about or what addon it was for at first. changed some stuff around removed some addons that don't work right, after taking some addons out like keypad and staker, i than tryed hosting a lan game again getting the error 1 more time ... uclip something null value bs than like ULX crashed after i noclip into the world and all ulx stuff stop working including the commands for it... but now for the life of me i cant get the error to come up again to copy and past it... wow I'm a big help ant i... maybe just a missload or something or maybe it don't like the Stargate, Life Support 2,  Resource Distribution 2, wire addons.
Offline kakashi1012
« Reply #68 on: January 22, 2008, 03:01:07 pm »
please make one for gmod 07 ;D
« Reply #69 on: January 22, 2008, 03:07:35 pm »
As far as we know, if you have the latest fixed SimplePropProtection (or, none at all), this still works fine.
Offline Pugnacious
« Reply #70 on: January 22, 2008, 10:12:51 pm »
This wasn't working on my server, but i'll test it again.  I was using a modified copy of Simple Prop Protection until they released an official version.  I updated to the officual version, so i'll test it again and report.
Mello
« Reply #71 on: April 13, 2008, 10:32:41 pm »
Is there a way to allow players to pass through any part of the map (walls, ground, etc.) ?
I'd like to have it so players can noclip through walls and such, just not props.
Thanks
« Reply #72 on: April 13, 2008, 10:42:27 pm »
Thanks
Not easily, no.
Mello
« Reply #73 on: April 14, 2008, 06:35:22 pm »
Alright, thanks anyways for the fast reply.
Re: Uclip v1.13 -- A noclip alternernative!
« Reply #74 on: April 21, 2008, 12:54:31 pm »
Updated, v1.13 released. Supports CPPI (means it will work with UPS and future prop protectors that use CPPI).
