Offline Sc00by22
Re: Uclip v1.13 -- A noclip alternernative!
« Reply #90 on: July 29, 2008, 12:20:51 pm »
I know you can noclip through peoples prop with Uclip and No Prop Protector, But does it still protect the world/skybox ect
« Reply #91 on: July 29, 2008, 12:47:35 pm »
Yes
Offline Cornflake
« Reply #92 on: August 22, 2008, 10:43:16 am »
SPP does not support Uclip, though it will soon.
What? I've been using SPP since the January update (as being like the only prop protetion system that even works) and Uclip ran with it fine. What the did garry frack up in the latest update so it no longer works with SPP?
Great, now I have to go back to manually Anti-Noclipping my entire base  >:(
Offline sparky2002b
  • CloudNine Clan Administrator
« Reply #93 on: August 22, 2008, 12:22:31 pm »
This isn't working for me.
It's installed correctly but players can still noclip through everything.
I use the latest SPP by Spacetech.
CloudNine Clan Server - 68.64.33.152:27019 - http://c9gc.com
Johnny Black
« Reply #94 on: September 01, 2008, 01:10:08 pm »
Im also using Simple Prop Protection and its not working for me, I've tried everthing I could find to try and fix.
« Reply #95 on: September 01, 2008, 03:58:06 pm »
Admins can still noclip through stuff by default.
RynO-SauruS
« Reply #96 on: October 01, 2008, 02:14:04 pm »
Will this work with the prop protection that is built into ASSMod?
« Reply #97 on: October 01, 2008, 03:09:04 pm »
Prop protectors supported: (if you don't have one of these everyone can noclip through every prop)
* PropProtection (recommended!)
* Simple Prop Protection
* EPS
* PropSecure
* Protector
First post.
RynO-SauruS
« Reply #98 on: October 02, 2008, 06:26:53 pm »
Thank you for the reply. I realize it that the first post says what it is compatible with, but I don't know whether or not it will work with the prop protection that is in ASSMod. A simple yes or no would suffice.
« Reply #99 on: October 02, 2008, 06:44:15 pm »
95% sure, no
Quote from: Megiddo
UClip is quite aged though. Perhaps ASSMod authors have written it to be compatible at popular request.
Unlikely, but possible.
RynO-SauruS
« Reply #100 on: October 02, 2008, 08:25:20 pm »
Thanks.
« Reply #101 on: October 03, 2008, 03:27:43 am »
It's old because there's nothing more to do. :P
Offline Hardy
« Reply #102 on: December 15, 2008, 09:19:10 am »
It's real to track player movement while in seats? Because they use no-collide right button and can infiltrate to any my base without any problems, or they can use ballsocket on world and flying thru world without any problems too.
« Reply #103 on: December 15, 2008, 03:55:24 pm »
To the former problem, use a (good) prop protector. To the latter, that's something garry's should fix, but failing that, just deny the advanced ball socket tool to everyone but admins.
Offline Dv2236
    • MyGamingVoid
« Reply #104 on: February 08, 2009, 02:38:08 pm »
I cant think of any bugs that's for sure its a grate little addon <3
but what about some new stuff like No Player Collision when in/not nocliped
examples
you minding your own business working on something mingbag walks up in noclip just over your head you cant move...
mingbags that might want to try and jump on your head anytime they can well you trying to wire stuff
Just a little idea maybe, <3 the addon
