Offline truck
Re: Uclip -- A noclip alternernative!
« Reply #15 on: July 26, 2007, 11:59:04 pm »
all... world and props
Offline Avien
« Reply #16 on: July 27, 2007, 07:41:26 am »
I tried using this addon but it does not allow people to noclip through my props even if i share the prop with them, or add them to my buddy list in PropSecure.  I thought this addon allowed that/
« Reply #17 on: July 27, 2007, 07:47:30 am »
Yes it allows for that, but during testing, we discovered PropSecure is riddled with security flaws right now. If/when these flaws are fixed in PropSecure, it will automatically work with UClip again.
Offline truck
« Reply #18 on: July 27, 2007, 10:11:52 am »
No idea for remove admin no clip??
Offline Chironex
  • Formerly known as Kyzer
« Reply #19 on: July 28, 2007, 05:23:13 pm »
Yes i would like to know too, because i would like to allow full noclip for a few groups, maybe. But as i said in my first post - and maybe i'm wrong - nowhere the adminCheck function is used somewhere else in the code, so i think it's useless :s,
Also we disabled it atm because of some problems that has been reported:
- players are stuck in players when they spawn (if a player was still at the spawn point, obviously) - confirmed as i saw it.
- players can't move forward with noclip while handling a prop -  not confirmed and strange as they own the prop...maybe false report.
- players are stuck in world sometimes, they need to suicide - confirmed.
I guess the last or two last of these problems can be difficult to fix, while the first should be easy, i hope you - try to - solve them for future version :)
« Reply #20 on: July 29, 2007, 01:04:07 pm »
Sorry, guess I forgot to stick the admin check in and was just using the previous version. I'll try to release a new version as soon as I'm back from vacation. :)
I've also discovered a consistent way you can go through props, working on a solution.
Offline truck
« Reply #21 on: July 30, 2007, 07:21:35 am »
Solution for remove admin right??
EDIT: Server alway crash when someone enter in a car. You need to fix that too
« Last Edit: July 30, 2007, 08:51:55 am by truck »
« Reply #22 on: July 31, 2007, 12:28:35 pm »
That crash has nothing to do with Uclip. Remember, we run Uclip on our servers too!
Offline Kingtendo
« Reply #23 on: July 31, 2007, 01:09:36 pm »
Don't know if it is just a coincidence, but i am also having the same problem as truck when this is on my server.
« Reply #24 on: July 31, 2007, 02:37:13 pm »
Okay, I just thought that you might mean that when you're noclipped and enter a vehicle, it crashes. I've tried doing this with both the release version and the version I have, no combination of noclip or vehicle crashes it. Apparently the move hook isn't even called when you're in a vehicle.
Once again, Uclip isn't causing your crash.
« Last Edit: July 31, 2007, 03:15:01 pm by Megiddo »
Offline truck
« Reply #25 on: July 31, 2007, 03:05:09 pm »
without uclip, my server dont crash when i go in a car and with uclip, OUPPP!! server crash. Very crazy??!!!
XD
« Reply #26 on: July 31, 2007, 03:15:47 pm »
XD
Can you describe exactly, step by step, what you're doing when it crashes?
Offline truck
« Reply #27 on: July 31, 2007, 03:32:36 pm »
Its very simple.... When you go in a car, you get noclip right??
For this moment, the server never crash if is a admin he enter in a car, only a normal player(because flying is only for player)
The server can crash only when a normal player go in a car(crash immediatly when you click on "e")
« Reply #28 on: July 31, 2007, 03:41:12 pm »
I've tried that multiple times now and still can't get it to crash.
Offline truck
« Reply #29 on: July 31, 2007, 03:47:00 pm »
Ok.... Do you try with Vehicule All in one??
