I am running 1.42 and when I check the client side errors I often see this on players joining the server for the first time.
Saint, see the post a few back.
Use the latest/greatest utime from our Github repository.
https://github.com/Nayruden/Ulysses
The last fix was 4 months ago, and code change added a check for nil cpanel.
DendeSon, Not sure by default, no.
However, you might look into the release named "UTime Hour Changer". I'm not sure if it has viewing/editing of offline players or not, but figure it would.
Offline SaintSin
I've managed to recreate another issue that has had the time reset after any server issues.
I changed a line of code on my server that created an error (compared a string to a number, idiot) in a pointshop file. This caused the player models to bug out along with all the other gamemode files. I noticed that in this broken server state it also over writes the players time. So any players that were online while I messed up had their time reset.
Offline benjanmin112
I got a bug with that me and some other players on my server are not able to see the utime up in our left cornor is they are way to fix this?!
/index.php/topic,3039.225.html#msg33186 or using the settings - Utime tab in your spawn menu.
We can't really control errors in other people's scripts...
Offline Nick_515
Sorry. I'm not great with this, but I'm getting these errors in console when people join for the first time. I have the newest version from GitHub and it includes the fix on line 40 of the cl_utime.lua.
[------------|33|STEAM_0:1:---------] Lua Error:
controlpanel.Get() - Error creating a ControlPanel!
You're calling this function too early! Call it in a hook!
[---------------|33|STEAM_0:1:---------] Lua Error:
[ERROR] addons/utime/lua/autorun/cl_utime.lua:310: attempt to index local 'cpanel' (a nil value)
1. buildCP - addons/utime/lua/autorun/cl_utime.lua:310
2. resetCvars - addons/utime/lua/autorun/cl_utime.lua:305
3. fn - addons/utime/lua/autorun/cl_utime.lua:334
4. unknown - addons/ulib/lua/ulib/shared/hook.lua:183
[--------------|33|STEAM_0:1:--------] Lua Error:
[-------------|33|STEAM_0:1:---------] Lua Error:
Dropped ------------ from server ("Too many Lua Errors! Sorry!")
This is on TTT. Not sure what other information is needed, but it's stopping new people from joining. :/
« Last Edit: December 31, 2013, 11:40:48 pm by Nick_515 »
Offline lopio1234
I have a question, wehre are the playerdata or rather is it possibel to modifiy the time of the player?
<clip>
1) Could have sworn we fixed the 'call it in a hook' error years ago.
Make sure you didn't mix old with new code on the server, and that your clients are getting latest?
Also, you can either set your "sv_kickerrornum 0" variable, or better yet, when experiencing an issue that bad with a addon, simply remove it after getting the details like you did.
In SQLite, which manifests itself as sv.db in the garrysmod root.
See release UTime Hour Changer
« Last Edit: January 03, 2014, 10:06:03 pm by JamminR »
Offline Nick_515
Yeah, I can't figure it out. I haven't mixed any code. I just downloaded the newest version and added it. :/
Offline HazCP
  • Founder of KGN
How do I move the utime over a couple of centimetres?
« Last Edit: January 26, 2014, 11:51:28 am by HazCP »
Offline zacciev
I run TTT, how do I edit utime?
« Last Edit: January 26, 2014, 02:44:04 am by zacciev »
Offline syn.
  • Lua Padawan
    • SynGaming
great addon by chaos /index.php/topic,6182.0.html let's you set a player's Utime Hours
Lua Student
"The more you understand, the crazier you get."
Go to the config.
Offline nogger
Can i ahve the patch for no errors to new players?
All current code is kept on GitHub, just like all our other projects. https://github.com/Nayruden/Ulysses
