Offline Avoid
Indeed, utime uses the inbuilt SQLite database, just copy your sv.db in server/garrysmod/.
Avoid
Hi people, do any of you know where the time data is stored?
I'm moving server hosts and I dont want my players to lose their time on my server.
Blast from the past!
where is the player time info stored for this addon?
In SQLite, which manifests itself as sv.db in the garrysmod root.
Offline Malkeur
I don't quite follow how to load sv.db into your mysql database.
Offline PatPeter
I have NO Lua errors, but every time I switch maps on my server, utime starts at 0! Has anyone else has this problem/know how to fix it?
A player on my server had Lua problems, but he hasn't given them to me yet.
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
sv.db is the mysql database. What are you even trying to do?
Sounds like a compatibility issue with another addon. Are you using sui_scoreboard by any chance?
FYI, it's my understanding its a SQLite database, not mysql.
Similar, but different enough to be a pain in conversion
... -.- :p
I forgot the "i" in mysql.
Offline Ticket
Can anyone let me know how? I can't see the settings.
Offline PatPeter
@chaos13125 I'm running Trouble in Terrorist Town, with custom editions to its scoreboard. Would that matter?
I'm looking in my sv.db file and it has a utime table with the fields:
id | player | totaltime | lastvisit
But there are no rows.
EDIT: I fixed the corruption and now it's saving again.
« Last Edit: August 09, 2014, 11:40:46 am by PatPeter »
Colors are controlled on client.
Start a single player listen server in Sandbox mode, you'll then be able to change stuff in settings.
I don't remember if UTime has color change settings though.
Also, why did you not ask this in the UTime thread???
EDIT - MERGED
« Last Edit: August 04, 2014, 09:46:45 pm by JamminR »
Offline frustratedgamers
Is this being developed still at all? Seems even like on a vanilla server it always will throw an error here and there.
Offline Neku
Works fine for me.
FrustratedGamers, there's a much newer code base at our Github, rather than using the link in first post.
Make sure you grab it (it's part of the Zip at github that comes with all our projects)
Offline nar308
Is there a reason why some players dont see the Total Session box at the top right corner?
Offline Avoid
utime_enable 1
