Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
utime_enable 1
Also could be that they're getting client side errors.
Offline PatPeter
All of the clients in my server occasionally get these messages, but when they do they're infinitely spammed in console:
[ERROR] addons/utime/lua/autorun/cl_utime.lua:77: attempt to call method 'GetWide' (a nil value)
  1. unknown - addons/utime/lua/autorun/cl_utime.lua:77
[ERROR] addons/utime/lua/autorun/cl_utime.lua:137: attempt to index field 'playerInfo' (a nil value)
  1. unknown - addons/utime/lua/autorun/cl_utime.lua:137
[ERROR] gamemodes/base/entities/weapons/weapon_base/cl_init.lua:160: attempt to index field 'Weapon' (a nil value)
  1. unknown - gamemodes/base/entities/weapons/weapon_base/cl_init.lua:160
Offline notownz
Here is my console error message, any help would be appreciated.
[ERROR] addons/utime/lua/autorun/cl_utime.lua:310: attempt to index local 'cpane
l' (a nil value)
  1. buildCP - addons/utime/lua/autorun/cl_utime.lua:310
   2. resetCvars - addons/utime/lua/autorun/cl_utime.lua:305
    3. fn - addons/utime/lua/autorun/cl_utime.lua:334
     4. unknown - addons/ulib/lua/ulib/shared/hook.lua:183
      5. LocalPlayer - [C]:-1
       6. fn - addons/ulib/lua/ulib/cl_init.lua:39
        7. unknown - addons/ulib/lua/ulib/shared/hook.lua:183
« Last Edit: October 15, 2014, 04:43:01 pm by notownz »
Offline petravic
On my server we have pointshop 2 and we had render lag on hats and accessories that is caused by utime wenn we removed utime all works fine.
« Last Edit: October 15, 2014, 03:55:56 pm by petravic »
Offline Wrath
How can I move the position of the box on my screen? o:
There's a configuration menu added to the same Gmod client side menus that Admin and "clean up" are on.
If you're not playing in Sandbox mode, I believe many gamemodes prevent that menu from opening.
The only one I knew that did it was dog fight (which is no longer an available gamemode with garry's mod.)
Offline PatPeter
So does anyone know how to fix this?
[Bean|188|STEAM_0:0:62527870] Lua Error:
controlpanel.Get() - Error creating a ControlPanel!
You're calling this function too early! Call it in a hook!
[ERROR] addons/utime/lua/autorun/cl_utime.lua:311: attempt to index global 'cpanel' (a nil value)
  1. buildCP - addons/utime/lua/autorun/cl_utime.lua:311
    3. fn - addons/utime/lua/autorun/cl_utime.lua:335
It's just a minor annoyance.
PatPeter, don't use the download from first post. At least, I think that's what you're doing.
Go get latest from our github.
It's included as part of the master zip file that contains all our github releases (you don't have to use all of them, only upload the addon folder from UTime (and ULib and ULX too)
https://github.com/Nayruden/Ulysses
Offline Toxic_Terrorists
Is there a way to view other players "last played on".
I mean this: [UTime]Welcome back Toxic_Terrorists, you last played on this server 01/19/15 21:42:24
But for admins to be able to see when a certain SteamID or player last played.
Offline Naunuk2424
Viewing other player's time
« Reply #295 on: February 18, 2015, 08:25:16 am »
As the servers coder i was hoping to use this to keep track of time for promotions. How do we view others time spent?
You'll have to search through the SQLite database for player entries, then work off the data there.
Alternatively, if you were seeking automated promotions, you could check out one of the many Autopromote addons.
Offline allofmywutsteam
  • MNWO Owner
    • MNWO Discord
Where does the addon store the hours? Is it hidden because I can't see any data logs that logs player x to hours x.
The reason i ask is because I had to wipe server after a year's worth of logged hours. So i'd like to see if I can recover that time.
All times are stored in sv.db, the SQLite database on the root of the server's files.
If you lost that, there is no recovery.
