Author Topic: Admin sounds, tools and other code chat.  (Read 95065 times)
Re: Admin sounds, tools and other code chat.
« Reply #15 on: April 10, 2008, 07:05:25 pm »
I changed my goal, I just want it to disable trails for non-admins wich it does. I also want it to display when a non-admin uses dynamite wich is currently not working. Any suggestions?
function UseTool( ply, tr, toolmode )
    if toolmode == "trails" or toolmode == "ignite" then
          if ply:IsAdmin() then
          return true
          return false
        if toomode ==  "dynamite" then
                                return true
                                Msg( "Player " .. ply:Nick() .. " used " .. toolmode .. "\n" );
                                return true
hook.Add( "CanTool", "UseTool", UseTool );
« Reply #16 on: April 10, 2008, 07:36:31 pm »
Getting any errors in server console?
Also, You may already be aware, "Msg" will only print to the console of the system it is run on... since CanTool is a server side gamemode hook, I believe it will only print in server console. Make sure you're looking there.
« Reply #17 on: April 10, 2008, 07:40:44 pm »
No I didn't know that msg displayed in the server console, but still it didn't print the message there either, nor did it display an error.
**EDIT**
I change my script alittle, but still no different.
          return true
          return false
                                return true
                                ConCommand( "Player " .. ply:Nick() .. " used " .. toolmode .. "\n" );
« Last Edit: April 10, 2008, 08:19:30 pm by jay209015 »
« Reply #18 on: April 11, 2008, 04:57:56 pm »
Sorry I didn't see this last night when I posted.
Syntax error in your code, misspelled variable - toomode in the dynamite check should be toolmode.
Also, ConCommand is for commands, not output of messages.
« Reply #19 on: April 11, 2008, 09:29:45 pm »
OMG thank you for seeing that lol, that's kind of sad :'(.
« Reply #20 on: April 11, 2008, 11:02:31 pm »
Ok, I got everything working. Here's the final code.
          return true
          return false
        if toolmode ==  "dynamite" then
                                return true
                                game.ConsoleCommand( "ulx asay Player " .. ply:Nick() .. " used " .. toolmode .. "\n" );
« Reply #21 on: April 12, 2008, 07:19:30 am »
Next thing you need to know in Lua 101... returning anything but nil (leaving blank/no variable after return) prevents any other hooks of the same type in any other scripts from running.
So, any of the code lines you have that return "true", remove the true. Just use return by itself.
Though the lines of code you have might not affect much by preventing other CanTool hooks, if you ever tried making a text chat watcher of any kind, you could break lots of scripts that also use chat hooks, including ULX.
« Reply #22 on: April 12, 2008, 09:06:16 am »
Oh, ok thanks for that. so you saying i should add
return true after
« Reply #23 on: April 12, 2008, 09:35:35 am »
nope.
Saying that any
return true
you have should be
return
I've forgotten the best way to prevent something from happening and not returning false.
MrPres, spbogie, Megiddo, Kyzer or any other lua folks out here... whats the best way to keep a hook from allowing that action, yet still not break other hooks?
« Last Edit: April 12, 2008, 09:39:06 am by JamminR »
« Reply #24 on: April 12, 2008, 10:53:53 am »
You return false but you still run the risk of breaking other hooks.
« Reply #25 on: April 12, 2008, 11:16:31 am »
This is on a different subject, but I don't feel it's necessary to open a new topic.
WordD = { "", "ass", "" }
function WFilter( ply, text, toall )
         for _, v in pairs( WordD ) do
             if string.find( text, v) then
                WordC = string.Replace(text,V,"****")
                return ..WordC..
                WordC = (text)
                return ..WordC..
hook.Add( "PlayerSay", "WFilter", WFilter );
I want this to replace the words in WordD when found in chat with **** , but I can't figure out how. Any help?
« Reply #26 on: April 12, 2008, 12:24:49 pm »
'return' will always end a loop.
Though your code _may_ find one word, it will stop looping.
Define a local variable before your for loop, such as local WordC = ""
than after the end of the for loop, -then- return WordC, and remove the other returns.
There is no need to use ".." before and after your WordC.
V does not equal v in lua.
Lua is case sensitive. You have the wrong case for one of you're variables.
« Last Edit: April 12, 2008, 12:32:02 pm by JamminR »
« Reply #27 on: April 12, 2008, 01:16:40 pm »
Ok, so is this what you're saying?
local WordC = ""
                WordC = string.Replace(text,v,"****")
                WordC = (text)
return WordC
BTW, thanks for the move, and all the help you've given me so far.
« Reply #28 on: April 12, 2008, 02:37:04 pm »
Yes, that should work.
To help make table loops faster, use ipairs instead of pairs when possible.
An experienced coder once taught me it was more efficient for the purpose your using it.
If you had a complex non-sequential numbered table, then you'd need pairs. Complex non-indexed example blah = { something = "else", old = "notnew" )
Since  you're using a simple table where WordD.1 = someword and WordD.2 = someotherword and WordD.3 = yetsomeotherword, you can use ipairs
i meaning indexed, 1, 2, 3...
« Reply #29 on: April 12, 2008, 02:42:25 pm »
But, do you know why this script isn't working at all?
