Author Topic: Admin sounds, tools and other code chat.  (Read 95065 times)
Re: Admin sounds, tools and other code chat.
« Reply #30 on: April 12, 2008, 03:11:42 pm »
This only filters out the word "", BTW the forums sensored the other two words
WordD = { "<censor>" }
local WordC = ""
function WFilter( ply, text, toall )
         for _, v in ipairs( WordD ) do
             if string.find( text, v) then
                WordC = string.Replace(text,v,"****")
                WordC = (text)
return WordC
hook.Add( "PlayerSay", "WFilter", WFilter );
« Last Edit: April 12, 2008, 04:40:37 pm by Megiddo »
« Reply #31 on: April 12, 2008, 04:40:05 pm »
Ok, so is this what you're saying?
WordD = { "<censor>", "ass", "<censor>" }
local WordC = ""
         for _, v in pairs( WordD ) do
                WordC = (text)
return WordC
BTW, thanks for the move, and all the help you've given me so far.
Untested, but try this
WordD = { "word" }
local found = false
text:gsub(v,"****")
found = true
if found then return text end
« Reply #32 on: April 12, 2008, 05:10:06 pm »
Code:
WordD = { "word" }
   local found = false
         text:gsub(v,"****")
         found = true
Tested, doesn't work
local WordC = ""
                WordC = (text)
return WordC
this one sensors out the last word in the WordD string , but breaks the ulx chat commands.
« Last Edit: April 12, 2008, 05:12:31 pm by jay209015 »
« Reply #33 on: April 12, 2008, 06:09:08 pm »
But, do you know why this script isn't working at all?
Two possibilities.
1) Tried removing the ( ) from your WordC= (text) ? Not sure why you have it. Pretty sure it's not needed.
2) http://www.lua.org/manual/5.1/manual.html#pdf-string.find - String find does pattern matching by default. Patterns are nice (but can be complex) ways of defining exactly what to look for without having to type more than necessary or make it easier to search for things that are hard to type (spaces for instance, special ascii characters, etc.)
Try changing your string.find to
string.find( text, v, 1, true)
« Reply #34 on: April 12, 2008, 06:28:36 pm »
Two possibilities.
Tested, but still this code only censors word2. Any idea as to why?
WordD = { "word1" , "word2" }
local WordC = ""
             if string.find( text, v, 1, true) then
                WordC = (text)
return WordC
« Reply #35 on: April 12, 2008, 09:36:17 pm »
local WordC = ""
                WordC = (text)
return WordC
I really hate lightbulb moments that show my stupidity.
I have a very good idea why.
This is 100% sillyness on my part (and maybe even others who attempted to help), nothing on you, as it is a mistake that a new coder (of _any_ language) could make.
WordC gets replaced with non-replaced "text" every single time it comes across a non-tabled word.
local WordC = ""
         WordC = text
             if string.find( WordC, v, 1, true) then
                WordC = string.Replace(WordC, v,"****")
return WordC
That should work. Hope you understand the difference. Your loop was setting WordC back to straight text on words not in the table.
« Reply #36 on: April 13, 2008, 08:39:36 am »
Again, same thing. Only censors word2 and breaks the ulx chat commands. Console doesn't return any errors, and I've ran lua_run PrintTable(WordD) and it shows everything as it should be. When we get this finished though I would like to see it released as a module with ulx because offensive language can get to be intolerable at times.
« Reply #37 on: April 13, 2008, 12:09:33 pm »
I tried it in singleplayer. The last code I gave you works fine, except yes, it breaks ULX chat commands.
I don't think it should break ALL chat hooks, but apparently not returning nil does.
I do not know why your examples aren't working.
Where are you testing this? What are you modifying? If testing on a dedicated server, are you restarting the server (not just the map) each change you make so that lua cache can be rebuilt?
I first said "This is a test of word1 word2"
It returned JamminR: this is a test of **** ****
I then said " This is a test of word1 and word2"
It returned JamminR: This is a test of **** and ****
Though you are more than welcome to make a release on your own, we will not add a word filter to ULX.
We've considered this a few times in the past and realized that it would be an effort in futility. As soon as you censor one word on a server, what I call the Gmod immature level increases 10 fold, and many on a server would start trying to find ways around the censor instead of building. I've seen it before with IRC chat bots back in the early 90s. People would get kicked from an IRC channel if they said a bad word, so instead, they'd rejoin and the only chat they'd do for 10 minutes or more (until a real admin banned them) would be to start replacing letters with numbers/symbols to represent another letter. It wouldn't surprise me one bit if 'leet speech' was invented by people doing such work arounds. Though you could increase the word table, that would start slowing down the script.
« Last Edit: April 13, 2008, 12:15:46 pm by JamminR »
« Reply #38 on: April 13, 2008, 12:24:27 pm »
Ok, thank you very much. I didn't restart the server, I just did the map. Also do you know of a way I can keep it from breaking the ulx chat commands, and how do I make it an addon?
« Reply #39 on: April 13, 2008, 12:30:40 pm »
I do not know how to prevent it from breaking other chat commands. You may wish to look into ULX to see how we do it, as I don't remember off the top of my head.
Addons are like virtual gmod folders.
Your folder would be something like the following
<addon_name>
in <addon_name> is required an info.txt. Look up one of your other addons for how that file is formatted.
Then, in <addon_name> folder, you place what folders/files that would be added to the Gmod folder if we were manually adding them.
In this case, you would need
<addon_name>/lua
<addon_name>/lua/autorun
<addon_name>/lua/autorun/filename.lua
There are other ways for larger lua files, where you just make the autorun link to those files but your script probably doesn't require a separate load.
« Reply #40 on: April 13, 2008, 12:35:30 pm »
Thank You!
« Reply #41 on: April 13, 2008, 12:43:41 pm »
Perhaps you could write a client side censor instead using Client hook "chattext" and have your server send it to clients.
http://garrysmod.com/wiki/?title=Gamemode.ChatText
No idea if this would break other things or not.
« Reply #42 on: April 13, 2008, 01:36:17 pm »
I tried, but I couldn't figure out how to make it work without using playersay. Maybe I could modify ulx to get it's player text from WordC rather than text
« Reply #43 on: April 13, 2008, 03:37:07 pm »
I was just looking at Megiddo's code example above. I believe his won't break ulx commands unless they include some of those censored words (such as in the name of the player or the reason provided for ban/kick).
You're always returning WordC/text, modified or not.
Gmod chat hooks will always stop other hooks from functioning if anything but nil is returned. (as we've discussed)
However, Megiddo uses a 'return' if nothing was found/edited, or the modified text if something was.
You can use his, or make slight modification to yours code that would look like the following
local WordC = nil
if WordC then return WordC else return end
In that code, WordC always gets set to nil everytime something is said.
If a censored word is found, it gets set in WordC. If not, WordC remains nil.
After it loops, if WordC has text, it is returned censored. If not, the hook is returned nothing, which should allow other scripts, such as ULX, to see the chat.
« Reply #44 on: April 13, 2008, 03:47:24 pm »
Tested and got this
word1
word2
word1 and word2
word1 and ****
word2 and word1
**** and word1
and it didn't break ulx
« Last Edit: April 13, 2008, 03:52:30 pm by jay209015 »
