Author Topic: AutoPromote  (Read 186526 times)
Offline HOLOGRAPHICpizza
    • GmodPlanet.com
Re: AutoPromote
« Reply #45 on: November 20, 2009, 08:41:42 pm »
Ok, I'm gonna do some testing and fix whatever is necessary and release a 1.1. MajorPain's looks like a complete rewrite with none of my code, but it has the same name...
Quote from: Jeremy S. Anderson
There are two major products that came out of Berkeley: LSD and UNIX. We don't believe this to be a coincidence.
Open Source • Net Neutrality • Ubuntu • Firefox • Sumatra PDF
Re: AutoPromote
« Reply #46 on: November 20, 2009, 08:50:52 pm »
Ah, ok. I'd not compared.
Make sure you're aware of the new command structure being used in SVN now.
Adduser hasn't changed too much, but it no longer allows immunity like the old (0/1) method.
I don't know if you did that automatically in any way in v1. See the SVN area of the forums. There's a sticky for how immunity is handled now.
Offline smithy
Re: AutoPromote
« Reply #47 on: December 27, 2009, 10:00:56 pm »
I'm not sure if this was actually broken or not from the posts(I didn't test Major_pains), but I optimised some of the code and added a chat announcement when people get promoted. I made this I wanted a version I know works and something that was exactly what i want.
Instructions:
As before in previous versions, pretty simple configuration - but its a bit different in this version.
Default settings:
Pretty self explanatory. Hours are when the promotion will take place. Group is the usergroup it will promote to. Name is what will be printed in chat when it says PLAYER has been promoted to name.
promotes = {
      { hours = 1, group = "player", name = "Player" },
      { hours = 2, group = "regular", name = "Regular" },
      { hours = 5, group = "respected", name = "Respected" },
      { hours = 10, group = "highrespected", name = "Highly Respected" },
      { hours = 25, group = "silverplayer", name = "Silver Player" },
      { hours = 50, group = "goldplayer", name = "Gold Player" }
Excludes work the same as previous versions, but are layed out differently.
excludes = { "donator", "moderator", "admin", "superadmin" }
Change msgOn to false if you want chat announcements disabled.
Change the below to change the color of the chat announcements.(Default is yellow)
Change effOn to false if you want effects/sound disabled.
settings = {
    { msgOn = true, msgcol = Color(255,225,0), effOn = true }
EDIT: Also, first post for me. xD
EDIT#2: Removed the links, download 3.1 in HOLO's post.
« Last Edit: December 30, 2009, 02:53:15 pm by smithy »
Offline smithy
Re: AutoPromote
« Reply #48 on: December 28, 2009, 08:14:44 pm »
Edited my last post with newer version, this is kinda a bump post. Anyway new stuff includes:
*Almost entirely recoded, simplified/optimised - can add as many groups as you like now, instead of Major_pains 10 alotted ones
*Chat announcement "Player has been promoted to 'Group name'." - Can disable if you don't like it, or change color of it.
*Effects and sound, when a player is promoted confetti appears and a sound is played. - Can disable if you don't like it.
*Easier configuration
*Works with SVN version of ULX
*Added awesomeness
If anyone can think of anything that would be good to include to AutoPromote I will gladly add it for you(granted its not too much hassle), also I will tell HOLOGRAPHICpizza that i posted here as he frequents a community I am in.
« Last Edit: December 28, 2009, 11:32:39 pm by smithy »
Offline Ploo
AutoPromote
« Reply #49 on: December 30, 2009, 12:04:45 pm »
I am using HoloGraphic Pizza's AutoPromote but having a problem.
local promoteGroups = {
-- Groups must be listed in decending order.
-- ["hours"] = "group",
["100"] = "platinum",
["50"] = "gold",
["20"] = "silver",
["5"] = "bronze",
["2"] = "member"
local excludeGroups = {
"dj",
"donator",
"mod",
"admin",
"superadmin"
It will promote up until bronze, but it fails to promote to silver (yes, past 20h). If I manually promote to silver it will demote to bronze. Yay.
Anyone know why? I'm certain my syntax is correct.
    • GmodPlanet.com
Re: AutoPromote
« Reply #50 on: December 30, 2009, 02:35:40 pm »
I made a few changes to Smithy's version and uploaded it to garrymod.org and updated the post.
v3.1 Changelog:
  • Now loads as a ULX module.
  • Calls ULX promote function directly, instead of through a console command.
Thanks Major_Pain and Smithy!
« Last Edit: December 30, 2009, 03:28:37 pm by HOLOGRAPHICpizza »
Offline Ploo
Re: AutoPromote
« Reply #51 on: December 30, 2009, 03:49:06 pm »
So wait, this is the new version, and I should disregard my problem and download this?
A new version released the very day I need it, how perfect. :D
Does not seem to work, the old one worked some-what... :S
if not SERVER then return end
--AutoPromote 2.0
--Automaticly promotes players to different groups based on UTime.
CREDIT FOR THIS VERSION OF AUTOPROMOTE GOES TO:
HOLOGRAPHICpizza
Major_Pain
Smithy
PRETTY SELF EXLANATORY
HOURS  IS THE POINT OF WHERE THE PLAYER WILL GET PROMOTED TO THE GROUP
NAME IS THE NAME THAT WILL GET DISPLAYED WHEN SOMEONE GETS PROMOTED
promotes = {
{ hours = 2, group = "member", name = "Member" },
{ hours = 5, group = "bronze", name = "Bronze Member" },
{ hours = 20, group = "silver", name = "Silver Member" },
{ hours = 50, group = "gold", name = "Gold Member" },
{ hours = 100, group = "platinum", name = "Platinum Member" }
---------IF A PLAYER IS A MEMBER OF THESE GROUPS THEY WONT GET PROMOTED.......EVER
excludes = { "dj", "donator", "mod", "admin", "superadmin" }
---------Chat announcement settings, msgOn  - if true then it will announce promotions(false if you want it disabled), msgcol - color of the chat announcements
settings = {
--------------------- DO NOT EDIT BELOW THIS LINE UNLESS YOU KNOW WHAT YOU ARE DOING---------------
if settings[1].effOn then
resource.AddFile( "sound/autopromote/promote.wav" )
local cID = 1
function checkExcludes( ply )
for id, eX in pairs (excludes) do
if not ply:IsUserGroup(excludes[id]) then
exclude = false
exclude = true
return exclude
function groupSet( ply )
local plhrs = math.floor((ply:GetUTime() + CurTime() - ply:GetUTimeStart())/60/60)
while plhrs >= promotes[cID].hours and cID < table.Count(promotes) do
cID = cID + 1
groupTS = promotes[cID-1].group
if cID == table.Count(promotes) then
groupTS = promotes[table.Count(promotes)].group
return true
if cID <= 2 then
if plhrs >= promotes[1].hours then
return true
if plhrs >= promotes[cID-1].hours then
return true
return false
function promotePlayer( ply )
if not checkExcludes( ply ) then
cID = 1
if  groupSet( ply ) and not ply:IsUserGroup(groupTS) then
if settings[1].msgOn then
for ud, blank in pairs( player.GetAll()) do
cID = table.Count(promotes) + 1
return true
ULib.tsayColor(player.GetAll()[ud],false,settings[1].msgcol,ply:Nick().." has been promoted to '"..promotes[cID-1].name.."'.")
cID = 1
effectS( ply )
WorldSound( "autopromote/promote.wav", ply:GetPos( 0, 0, 0 ), 160, 100 )
ulx.adduser(nil, ply, groupTS)
--game.ConsoleCommand("ulx adduser "..string.format("%q", ply:Nick() ).." "..groupTS.."\n")
if not timer.IsTimer("Promotion-" ..tostring(ply:SteamID())) then
timer.Create("Promotion-" ..tostring(ply:SteamID()), 10, 0, promotePlayer, ply)
function effectS( ply )
local ed = EffectData()
ed:SetEntity(ply)
util.Effect("autopromotion",ed, true, true)
local vPoint = ply:GetPos()
local effectdata = EffectData()
local r = math.random(20, 255)
local g = math.random(20, 255)
local b = math.random(20, 255)
effectdata:SetStart( Vector( r, g, b ) )
effectdata:SetOrigin( vPoint )
effectdata:SetScale( 1 )
util.Effect( "autopromotion2", effectdata )
timer.Simple( 1, function()
end)
timer.Simple( 2, function()
end)
timer.Simple( 3, function()
end)
timer.Simple( 4, function()
end)
function timerStart( ply )
hook.Add( "PlayerInitialSpawn", "timerstarting", timerStart)
function destroyTimers(ply)
if timer.IsTimer("Promotion-" ..tostring(ply:SteamID())) then
timer.Stop("Promotion-" ..tostring(ply:SteamID()))
timer.Destroy("Promotion-" ..tostring(ply:SteamID()))
hook.Add( "PlayerDisconnected", "PromotionCleanUP", destroyTimers )
« Last Edit: December 30, 2009, 05:01:43 pm by Ploo »
Offline smithy
Re: AutoPromote
« Reply #52 on: December 30, 2009, 06:18:10 pm »
Add me on steam Ploo and I'll try and help you. :)
« Last Edit: May 30, 2011, 02:09:29 pm by smithy »
Re: AutoPromote
« Reply #53 on: December 30, 2009, 08:32:50 pm »
Smithy released a version of his own within holographic pizza's.
Prob should have made his own release - Smithy's Autopromote or something similar.
Offline smithy
Re: AutoPromote
« Reply #54 on: December 30, 2009, 09:01:56 pm »
It's not a new script though, its based from HOLO's.
Version 3.1 that HOLO released is just my v3 version in modular form, with slight fixes. We worked together on 3.1.
There is no need for a new thread for the same addon, am I right?
Anyway Ploo if you are still having problems add me on steam, like I said it has been tested and works fine - so its probably misconfiguration somewhere.
Offline Ploo
Re: AutoPromote
« Reply #55 on: December 31, 2009, 03:34:12 am »
Added you.
Offline smithy
Re: AutoPromote
« Reply #56 on: January 03, 2010, 10:19:14 pm »
I realised a major flaw in my code so here is 3.2. I will ask HOLO to reupload to garrysmod.org, but for now here is a temp mirror.
DOWNLOAD
Version 3.2 changes:
*Fixed the exclude group code, it was only excluding the last group in the excludes table. - Fixed in V3.2
« Last Edit: January 03, 2010, 10:21:42 pm by smithy »
Re: AutoPromote
« Reply #57 on: January 04, 2010, 01:30:39 am »
*Fixed the exclude group code, it was only excluding the last group in the excludes table. - Fixed in V3.2     - Nice find! :)
Offline TweaK
    • Garry's Mod Engineers
Re: AutoPromote
« Reply #58 on: January 08, 2010, 01:32:34 am »
So I am trying to get this thing to work... first here is what i have for a config:
promotes = {
{ hours = 2, group = "player", name = "Player" },
{ hours = 10, group = "regular", name = "Regular" },
{ hours = 25, group = "pro", name = "Pro" },
{ hours = 45, group = "vip", name = "VIP" },
{ hours = 75, group = "respected", name = "Respected" }
excludes = { "respected", "admin", "admin2", "superadmin" }
and what is happening is it will promote to player, regular, pro...but when a player hits 45 hours it jumps to respected and skips vip... or whatever the second to last group defined is in any case...
any ideas? ??? or am i just crazy
edit: i dont think having respected in the excludes makes a difference but im not 100% on that
Offline someone920
Re: AutoPromote
« Reply #59 on: March 06, 2010, 06:23:34 am »
I have the same problem as TweaK..
