Author Topic: AutoPromote  (Read 186526 times)
Re: AutoPromote
« Reply #75 on: April 03, 2010, 09:16:27 am »
K I'll try reversing it later, people in server right now.  I'll let you know if it worked.
Re: AutoPromote
« Reply #76 on: April 03, 2010, 05:23:05 pm »
Seems I was wrong. Jay's correction from a few posts above yours, shows in order least to greatest.
HOURS  IS THE POINT OF WHERE THE PLAYER WILL GET PROMOTED TO THE GROUP
NAME IS THE NAME THAT WILL GET DISPLAYED WHEN SOMEONE GETS PROMOTED
promotes = {
{ hours = 1, group = "player", name = "Player" },
{ hours = 2, group = "regular", name = "Regular" },
{ hours = 5, group = "respected", name = "Respected" },
{ hours = 10, group = "highrespected", name = "Highly Respected" },
{ hours = 25, group = "silverplayer", name = "Silver Player" },
{ hours = 50, group = "goldplayer", name = "Gold Player" }
But, it could depend on which version you're using. Several fixes/enhancements/versions exist within these pages.
Re: AutoPromote
« Reply #77 on: April 03, 2010, 07:42:53 pm »
I have no idea which I should use.  I am using the latest SVNed version of ULX if that has anything to do with it.  I also just downloaded UTime just a couple days ago.  So maybe there was a change that broke it?
Offline phoenixf129
Re: AutoPromote
« Reply #78 on: April 04, 2010, 05:06:28 am »
I keep getting a re-occuring error:
 ulx\modules/AutoPromote.lua:65: 'then' expected near '='
Offline someone920
Re: AutoPromote
« Reply #79 on: April 04, 2010, 08:52:34 am »
If you guys want, I'll add mine, it's working perfectly. Only thing you have to do is add the last group to the list that won't be promoted... ever.
Re: AutoPromote
« Reply #80 on: April 04, 2010, 03:41:28 pm »
Sure I'll take it.
Offline someone920
Re: AutoPromote
« Reply #81 on: April 04, 2010, 06:55:17 pm »
if not SERVER then return end
CREDIT FOR THIS VERSION OF AUTOPROMOTE GOES TO:
HOLOGRAPHICpizza
Major_Pain
Smithy
Jay209015
PRETTY SELF EXLANATORY
promotes = {
{ hours = 3, group = "member", name = "Member" },
{ hours = 10, group = "b_member", name = "Bronze Member" },
{ hours = 30, group = "s_member", name = "Silver Member" },
{ hours = 60, group = "g_member", name = "Gold Member" },
{ hours = 120, group = "p_member", name = "Platinum Member" }
---------IF A PLAYER IS A MEMBER OF THESE GROUPS THEY WONT GET PROMOTED.......EVER
excludes = { "supporter", "moderator", "administrator", "superadmin", "vip", "s_admin", "p_member", "storm" }
---------Chat announcement settings, msgOn  - if true then it will announce promotions(false if you want it disabled), msgcol - color of the chat announcements
settings = {
{ msgOn = true, msgcol = Color(255,225,0), effOn = false }
--------------------- DO NOT EDIT BELOW THIS LINE UNLESS YOU KNOW WHAT YOU ARE DOING---------------
if settings[1].effOn then
resource.AddFile( "sound/autopromote/promote.wav" )
function checkExcludes( ply )
for id, eX in pairs (excludes) do
if ply:IsUserGroup(eX) then
return true
return false
function hoursToPromote( group )
for id,_ in ipairs( promotes ) do
if group == promotes[id]["group"] then
return promotes[id]["hours"]
function getPromoteName( group )
return promotes[id]["name"]
function groupSet( ply )
ply.plhrs = math.floor((ply:GetUTime() + CurTime() - ply:GetUTimeStart())/60/60)
ply.promote = promotes[1]["group"]
for id,_ in ipairs(promotes) do
if ply:IsUserGroup(promotes[id]["group"]) and id < table.Count(promotes) then
ply.promote = promotes[id + 1]["group"]
if not(ply:IsUserGroup(ply.promote)) and (ply.plhrs >= hoursToPromote( ply.promote )) then
return true
return false
function promotePlayer( ply )
if not checkExcludes( ply ) then
if  groupSet( ply ) then
if settings[1].msgOn then
for ud, blank in pairs( player.GetAll()) do
ULib.tsayColor(player.GetAll()[ud],false,settings[1].msgcol,ply:Nick().." has been promoted to '"..getPromoteName(ply.promote).."'.")
effectS( ply )
WorldSound( "autopromote/promote.wav", ply:GetPos( 0, 0, 0 ), 160, 100 )
ulx.adduser(nil, ply, ply.promote)
if not timer.IsTimer("Promotion-" ..tostring(ply:SteamID())) then
timer.Create("Promotion-" ..tostring(ply:SteamID()), 10, 0, promotePlayer, ply)
function effectS( ply )
local ed = EffectData()
ed:SetEntity(ply)
util.Effect("autopromotion",ed, true, true)
local vPoint = ply:GetPos()
local effectdata = EffectData()
local r = math.random(20, 255)
local g = math.random(20, 255)
local b = math.random(20, 255)
effectdata:SetStart( Vector( r, g, b ) )
effectdata:SetOrigin( vPoint )
effectdata:SetScale( 1 )
util.Effect( "autopromotion2", effectdata )
timer.Simple( 1, function()
end)
timer.Simple( 2, function()
end)
timer.Simple( 3, function()
end)
timer.Simple( 4, function()
end)
function timerStart( ply )
hook.Add( "PlayerInitialSpawn", "timerstarting", timerStart)
function destroyTimers(ply)
if timer.IsTimer("Promotion-" ..tostring(ply:SteamID())) then
timer.Stop("Promotion-" ..tostring(ply:SteamID()))
timer.Destroy("Promotion-" ..tostring(ply:SteamID()))
hook.Add( "PlayerDisconnected", "PromotionCleanUP", destroyTimers )
So just see that p_member is the last group players get promoted to but they are also in the excluded, if you don't do that with your last group, it's going to go in a loop.
Re: AutoPromote
« Reply #82 on: April 06, 2010, 07:43:05 pm »
HOLOGRAPHICpizza
Major_Pain
Smithy
Jay209015
promotes = {
settings = {
return true
return false
return true
return false
effectS( ply )
ed:SetEntity(ply)
end)
end)
end)
end)
Thanks that strangely worked perfectly. ;D
Offline Simple
Re: AutoPromote
« Reply #83 on: May 08, 2010, 05:20:38 am »
Is this compatible with ULX and ULIB SVN?
Re: AutoPromote
« Reply #84 on: May 08, 2010, 09:38:15 am »
Read the last three posts before yours.
Aaron says he's using SVN, Someone920 provides working code.
Offline Tucker
Re: AutoPromote
« Reply #85 on: June 17, 2010, 12:29:49 pm »
For some reason I can't get it to work. Here's my code.
local promoteGroups = {
--   Groups must be listed in decending order.
--   ["hours"] = "group",
   ["100"] = "dedicatedmember",
   ["60"] = "highlyrespected",
   ["40"] = "moderatlyrespected",
   ["20"] = "lightlyrespected",
   ["10"] = "regular",
   ["2"] = "builder"
   ["0"] = "user"
Re: AutoPromote
« Reply #86 on: June 17, 2010, 01:17:49 pm »
Unless there was an update on it, that is not even close to how your suppose to do it.
promotes = {
{ hours =2, group = "builder", name = "Builder" },
{ hours = 10, group = "regular", name = "Regular" },
{ hours = 20, group = "lightlyrespected", name = "Lightly Respected" },
{ hours = 40, group = "moderatlyrespected", name = "Moderately Respected" },
{ hours = 60, group = "highlyrespected", name = "Highly Respected" },
{ hours = 100, group = "dedicatedmember", name = "Dedicated Member" }
And make sure you use the working code that someone920 gave me.
Offline someone920
Re: AutoPromote
« Reply #87 on: July 09, 2010, 02:24:55 pm »
it seems Garry's last update broke my autopromote, anyone else have the same problem?
Re: AutoPromote
« Reply #88 on: July 09, 2010, 03:19:18 pm »
<clip>anyone else have the same problem?
For those that might be, what, other than it not promoting, is the problem?
Errors? Symptoms?
Offline someone920
Re: AutoPromote
« Reply #89 on: July 09, 2010, 03:55:46 pm »
I've been watching it all day, but there are no errors so far, but i just remembered, I don't have a cl_utime.lua for my utime, could that cause the problem?
