« Reply #120 on: July 31, 2011, 09:58:31 pm »
I'm not entirely sure it is FPP as I didn't bother to look for it.  Any ideas Setup?  Do you have something else installed that messes with tools?  (Assuming you'll come back and check this topic.)
Offline Maor360
« Reply #121 on: August 01, 2011, 02:42:18 am »
And I have the css guns and i want to disable them too .
how to do it?
Thanks ;)
« Reply #122 on: August 01, 2011, 11:53:34 am »
Either I really need to finish rewriting the original post or you're not trying.  I'll try to finish rewriting it today.
ulx restrict swep [swep name] [groups]
Try using the GUI.  It's easier then using the commands.
EDIT:  Actually, I think I'm going to whip something up on my site.
« Last Edit: August 01, 2011, 12:43:13 pm by Aaron113 »
« Reply #123 on: August 01, 2011, 02:30:58 pm »
http://aaron113.com/urs.php
Well here is what I have done.  I'm still learning about HTML and what not so sorry for the site looking a big crappy.  I might move this to a wiki page in the future.  Suggestions are welcomed.
Hope it helps.
« Last Edit: August 01, 2011, 07:21:40 pm by Aaron113 »
« Reply #124 on: August 01, 2011, 03:23:34 pm »
He's not trying/researching on his own. Lots of spoon fed around here.
Give 'em squirrel.
But the write-ups you do/did will help those who like to help themselves.
Offline Maor360
« Reply #125 on: August 01, 2011, 10:49:41 pm »
Thanks!
« Reply #126 on: August 04, 2011, 11:14:57 am »
Added http://aaron113.com/urs.php to the main post.  It is pretty much finished.
Offline Willdy
« Reply #127 on: August 04, 2011, 01:50:32 pm »
How do you set immunitys?
I did
ulx restrict swep weapon_ak47 * donator
to restrict the ak47, for everyone except people in the donator group.
It returned..
You restricted swep weapon_ak47 from *, donator
« Reply #128 on: August 04, 2011, 02:04:27 pm »
Yes, that's how it should return.  I suppose I could put in a "everyone except blah".  Is that what you were looking for?
« Reply #129 on: August 04, 2011, 02:39:43 pm »
The explanation on your site looks nice, Aaron! You would be able to replicate that same look here on the forums here using lists and divs. The forums also support basic HTML codes, lists and hr's are probably among them.
Offline Willdy
« Reply #130 on: August 04, 2011, 02:52:50 pm »
Yea it was, im sure I read somewhere that you posted that's how to do it, but maybe I didn't. I can't find it written anywhere.
Also, when I was trying to restrict tools, I wanted to make it so only a certain group could use the 'Balloon' tool, but despite my efforts to restrict it, it wouldn't go restricted.
What should I have put for the name? I tried "Balloons" and "Balloon".
« Reply #131 on: August 04, 2011, 03:55:08 pm »
When you use a tool on anything it should echo into your console, "[Name]<[SteamID]> used the tool [tool name] on [what ever the tool was used on]."  Just take the [tool name] part and use what that echos.
I didn't realize that, but I didn't want to make my main post too long.  And Thanks!
Offline Willdy
« Reply #132 on: August 04, 2011, 03:58:39 pm »
It doesn't say that O.o
« Reply #133 on: August 04, 2011, 04:11:18 pm »
Make sure you have access to "ulx spawnecho".  It should work fine.
Aaron113<STEAM_0:0:25464234> used the tool balloon on maps/gm_construct.bsp
Offline Willdy
« Reply #134 on: August 04, 2011, 04:16:05 pm »
I get messages like..
«[N-G]» Willdy :3<STEAM_0:0:22970989> spawned model models/props_c17/streetsign004e.mdl
But I still don't see tool echos :/
