« Reply #135 on: August 04, 2011, 09:36:36 pm »
Ahh, I think I know where this is going.  Can you give me a complete list of your server's addons?
Offline Willdy
« Reply #136 on: August 05, 2011, 01:55:33 am »
Might be more the fact its a Sledbuild server. (A very buggy, discontinued gamemode)
« Reply #137 on: August 05, 2011, 12:30:54 pm »
Possibly.
Offline blackfire88
« Reply #138 on: August 06, 2011, 12:44:56 am »
Have you got per-player done yet?
« Reply #139 on: August 06, 2011, 07:22:43 am »
It's 4th on my todo.  I plan to start working no my Todo again soon.
Offline killforfun
« Reply #140 on: August 06, 2011, 11:09:00 am »
Ahhh i found a way to get past the prop limit If the player has past the prop limit he can still use the stacker tool to and stack them and go over limit could you fix that
« Reply #141 on: August 06, 2011, 11:35:13 am »
Yeah, it's on my todo.  It just kept on getting bumped down because of more important things.
« Reply #142 on: August 06, 2011, 03:07:06 pm »
Aaron, you should put a urs_readme.txt in your main svn addon/urs folder with links pointing to your 'how to', and, because I get frustrated with people asking/mentioning items you've already discussed in past posts, to do's,  and changelogs, add your ToDo and Changelogs to it.
This way, if someone asks a question thats already been included in URS, or a 'has this been done yet?', we can assist you by pointing them to the urs_readme.txt link.
« Reply #143 on: August 06, 2011, 04:00:00 pm »
Will do.  Can tell you've got some experience with this. :P
« Reply #144 on: August 06, 2011, 05:33:23 pm »
A little. :)
You'll find it helps you directly too.
Even if you have a local file or place that you put smaller 'to do' items, it can help you prioritize the bigger ones.
That, and if you update the file every time you update/fix/add some code, helps you avoid squirrels.
I mean, sure, they're great to have fun with once in a while, but, they're distracting during the middle of a coding session.
Lose sense of direction at times.
« Reply #145 on: August 08, 2011, 07:40:13 pm »
Everything is working fine on my side.  Do you get any errors?  Copy and paste what the command "ulx print all" echos into your console.  Did it work before or break recently?  If so, have you added any new addons since it broke?
Offline logan
« Reply #146 on: August 11, 2011, 07:48:44 pm »
Alright... I have this on my server, yet I cannot restrict anything. I go to the tab and all, yet when I click 'tools' no tools are available in the list. The only things available are the guns. :(
I need this, even willing to pay.
« Reply #147 on: August 11, 2011, 08:55:24 pm »
@logan
Type "ulx print all" and copy and paste the echo that it puts into your console.  Also, do you happen to get any errors?  What exactly is the problem?  What do you mean by no tools are available on this list?  If you're talking about a list of tools, I do not believe there is a way to retrieve a list.  I can do some further looking into it but no promises.
If you would, give me an example of what you're typing in to restrict.
EDIT:  Also check out http://aaron113.com/urs.php
@HeLLFox_15
I cannot do much if I do not know the cause of the problem.  If at all possible, I'll need to come on your server and find the issue.
« Last Edit: August 12, 2011, 01:28:56 pm by Aaron113 »
Offline logan
« Reply #148 on: August 14, 2011, 05:22:20 pm »
I cannot restrict ANYTHING besides weapons, as I said. I want to restrict certain Wire tools and adv duplicator, things like that. If we could talk via steam it would be greatly appreciated.
My username is:
logan1010
« Reply #149 on: August 14, 2011, 06:14:22 pm »
logan's problem is resolved...  Still having issues with yours Fox?
