Offline Mors Quaedam
« Reply #315 on: April 05, 2013, 10:41:51 am »
Presumably this isn't working with the latest version of GMod then, just by reading up the thread?
« Reply #316 on: April 05, 2013, 01:37:54 pm »
I assume it would work if you follow this ( https://docs.google.com/document/d/1khSuIYrAMkqXu7wlH5YRJNwz6hOH6Xqi5lqBhE3x6gA/edit )
And check to make sure that every thing fits the new format.
How ever there is probably no longer any support from the OP because I have not seen him online in ages.
Offline TweaK
    • Garry's Mod Engineers
« Reply #317 on: April 05, 2013, 04:59:45 pm »
The one I linked a few posts back on the previous page should be working fine. https://dl.dropbox.com/u/7934790/gmod/urs.zip
« Reply #318 on: April 05, 2013, 05:40:36 pm »
It's not just a matter of a changed API, HeLLFoX, it's that the API is glitched.
« Reply #319 on: April 07, 2013, 04:01:41 pm »
Thanks.
« Reply #320 on: April 08, 2013, 06:51:47 am »
I have a terrible feeling this is affecting the performance of my server. When it's installed, my server lags to after a while. Now it's removed, my server is fine.
Offline attacker1983
« Reply #321 on: April 08, 2013, 10:18:40 am »
<user quoted entire first post>
question WHERE THE <censor> DO I DOWNLOAD
EDIT-JamminR-Removed entire quote of first post. Read just a little bit. Old tpoics usually have the best info in the last 2-3 pages. This is true on any forum, not just Ulysses.
« Last Edit: April 08, 2013, 09:19:13 pm by JamminR »
Offline TweaK
« Reply #322 on: April 08, 2013, 08:50:47 pm »
Why doesn't anyone here read? It's four posts above you...
« Reply #323 on: April 08, 2013, 09:17:23 pm »
Good question.
Don't think it will ever truly be answered.
Most Gmod players lazy perhaps?
Offline Tristian Wood
« Reply #324 on: April 10, 2013, 11:02:08 pm »
Worth a shot. Or, try this: backup and delete (or just rename) your restrictions.txt limits.txt loadouts.txt files in data/ulx, startup server, add some test values using the menu, run "ulx print all" in your console as an admin and it should print all the values you added, then restart your server and run the command again, it should print the same thing if it is actually loading the files.
Also, are you getting any lua errors?
I tried that way but it didnt work and no i didnt have any lua errors. I shall try the one you just gave out a few posts ago.
Owner of soul gaming
Offline TweaK
« Reply #325 on: April 11, 2013, 01:41:39 am »
That one was just a repost of the same one for the new page. If it's still broken after trying that I'd start looking into addon conflicts... try with the bare minimum ulx ulib urs and see if it still happens.
« Reply #326 on: April 14, 2013, 05:44:06 am »
I unpacked the one on  the steam workshop and used that, seems to work now. Just had to play around with the data files to convert them to that version.
« Reply #327 on: April 14, 2013, 07:15:12 am »
Hi.  Wow there's been a lot of activity in this topic since I've last been here.  Once again though, if anyone wants access to the repo to work on it, ask.  I'm far too busy right now to work on this.
EDIT:  Perhaps I can find some time.
« Last Edit: April 14, 2013, 07:20:40 am by Aaron113 »
Offline TweaK
« Reply #328 on: April 14, 2013, 08:55:41 am »
Hmm. Well I know the ui is screwy on the workshop version... in my version I changed the data files to table-to-keyvalues instead of table-to-json just to be consistent with the rest of ulx/ulib, I'm starting to wonder if maybe I shouldn't have done that... or if there is another reason that it wasn't working for you.
I could upload my version, as far as I know it is completely working aside from whatever Tristian's issue was... is the SVN still the gm12 version? Or are you talking about the Workshop?
« Reply #329 on: April 14, 2013, 09:45:23 am »
I've actually fixed everything (that I could find).  I just don't know where the url to commit my changes is... heh.  It's been a few months since I've used this, and it doesn't help that I've gotten a new computer and reinstalled it twice since then.
EDIT: Found it and uploaded the changes.
EDIT2:  So if it doesn't work, delete the data files URS makes and it should work after you restart.  You'll just have to redo all your settings.
« Last Edit: April 14, 2013, 09:51:52 am by Aaron113 »
