Offline Spider
« Reply #345 on: May 31, 2013, 02:42:34 pm »
I'm kinda confused as what it means by type. Ulx restirct type
What is the type?
Offline Spider
« Reply #346 on: May 31, 2013, 04:10:55 pm »
Hello
Can you give an example of one of the ulx restrict commands? Like instead of saying what to put actually put an examble
« Reply #347 on: May 31, 2013, 10:04:10 pm »
Review the 20+ pages.
Don't have to read every post, but, really...just look a little bit...surely others have asked similar questions, and we prefer not to repeat what's already been answered.
Offline eagle9er9er
« Reply #348 on: June 05, 2013, 05:28:31 pm »
URS does not show up in my GUI? But when I go to superadmin permissions Ulx Restrict is under "_UnCategorized_".
« Reply #349 on: June 07, 2013, 05:01:37 pm »
Eagle, you and one other are reporting this.
Gmod just updated...it's possible something went awry there.
Aaron may have made an update (less sure of that)
Stickly may have tinkered in XGUI (always possible)
Let's let the auhors see this latest commentary.
« Reply #350 on: June 08, 2013, 08:26:24 am »
I just installed and tested URS on my local dev server and it was working fine :-\
« Reply #351 on: June 08, 2013, 05:20:54 pm »
So it's likely a addon or gamemode breaking the 'categorization' within URS and ULib.
Offline eagle9er9er
« Reply #352 on: June 09, 2013, 03:55:45 pm »
Any possible way to figure this out? It's frustrating having noobs come on and use duplicator to crash my server.
« Reply #353 on: June 09, 2013, 08:11:18 pm »
Yes, take off every addon you've ever added, and run server in sandbox.
Test if it works.
Yes?
Load server in whatever game mode you're running in to see if it works.
Yes?
Start adding back addons 2-3 at a time.
Stop working?
Remove the last 2-3 you added...add one back at a time until you find the one that breaks.
Also, You never stated that URS wasn't working for you.
You simply stated the categorization was off.
Look for URS errors in console during startup and use of the commands, both in server console and client console.
Report them here.
Offline eagle9er9er
« Reply #354 on: June 09, 2013, 10:22:13 pm »
I can't even use the console commands. It says the commands doesn't exist.
Edit: So I uninstalled all my addons and tried to see if anything was breaking URS, and even with everything uninstalled it still doesn't work.
I really don't know what to do at this point. Console commands don't work (ulx restrict), and its still "_Uncategorized".
« Last Edit: June 10, 2013, 09:53:53 am by eagle9er9er »
« Reply #355 on: June 10, 2013, 06:40:38 pm »
1) I've seen postings that Gmod server needs to be updated now using 'SteamPipe' and not "HLDS" ... done that?
2) Did you try running server in Sandbox (it could be another gamemode breaking it)
3) Define "not work" - did you get a console error when running the command? Does URS error at startup (look both server log at startup, and in player console at connect (on server and client)?
The fact it says 'uncategorized' shows something is being seen.
Are you running latest ULX/Ulib from our github repo/SVN?
Offline eagle9er9er
« Reply #356 on: June 10, 2013, 08:20:43 pm »
1. My server is updated to Steampipe.
2. My server is in sandbox.
3. Not work. As in, the console commands don't work at all, they apparently don't exist as a command, nor can I do anything to do with URS.
4. I do not see anything, error or just in general related to URS appearing in the console on startup.
Offline Hyperion
« Reply #357 on: July 05, 2013, 05:39:33 am »
This addon is awesome, but I can't block some items, which is frustrating me. For example the bouncy ball- it allows people to cheat by adding more health, or all insurgency weapons are unblockable, like if things with a sent_ prefix in their name (or sim_) were not working with the URS. Also, is it possible to block some SCars? Tried copying their names to vehicles and sents, or blocking the models, but didn't help
Offline Epsilon
« Reply #358 on: July 05, 2013, 02:35:28 pm »
I'm also having trouble banning dynamite. I can ban the tool just fine, but can't seem to prevent people from simply using dupes with dynamite attached (Even banning the model doesn't work).
Offline eagle9er9er
« Reply #359 on: July 06, 2013, 12:14:18 pm »
I need help really badly, how to I restrict wire tools? I want to restrict E2 from Guests but no matter how I type "Expressions 2, Expressions tool" or whatever it doesnt work.
