Offline Wully616
    • WullysGamers
« Reply #375 on: July 29, 2013, 10:16:17 am »
Would there be any way to edit this to include custom sbox_limits, for example I'm trying to limit sbox_max_acf_ammo so that new players can't spawn ammo, for fear of minges but later ranks can.
The only line I could find which might be the one to edit is in urs_server.lua:
local limittypes = { "vehicle","effect", "npc","ragdoll","prop","sent" }
Would I simply add in "acf_ammo" to that list?
[/url]
Offline Epsilon
« Reply #376 on: July 29, 2013, 12:10:53 pm »
I was wondering the same thing with regards to all the default sbox limits as well.
« Reply #377 on: July 30, 2013, 01:32:09 pm »
You can limit the weapons that are spawned?  You can do the same with picking up the weapons.
ulx restrict swep weapon_ar2 superadmin
I do not do much with sbox limits.  It's all done with lua and any custom limits you set.  I merely hook into the spawning and check how many you have.
« Reply #378 on: July 30, 2013, 03:44:27 pm »
I just fixed an Advanced Duplicator 2 issue someone was having.  That took forever but I pushed it out already.  I also updated the main page with updated links and what not.  The wiki is just starting out but I'll update it more.
Offline Epsilon
« Reply #379 on: July 31, 2013, 03:15:36 am »
So, can you explain how one might add more custom limits, such as a limit for sbox_dynamite?
« Reply #380 on: July 31, 2013, 11:40:15 am »
You want to limit the amount of dynamite able to be spawned for each group?  There is currently no real easy way to add that.  You/I would have to do a bit of coding for that.  I created a issue (which is also sort of like a todo) on github.
https://github.com/Aaron113/URS/issues/3
Also, any feedback on the new wiki would be appreciated.  You can even edit it yourself if you wish.
https://github.com/Aaron113/URS/wiki
Offline Tristian Wood
« Reply #381 on: August 11, 2013, 08:30:39 pm »
Today I fresh installed URS and ULX and I got this error after typing in ulx print all
[ERROR] lua/includes/modules/net.lua:66: bad argument #1 to 'pairs' (table expected, got nil)
1. pairs - [C]:-1
2. WriteTable - lua/includes/modules/net.lua:66
3. call - addons/urs/lua/ulx/modules/sh/urs_cmds.lua:194
4. __fn - addons/ulib/lua/ulib/shared/commands.lua:943
5. unknown - addons/ulib/lua/ulib/shared/commands.lua:1296
6. Run - lua/includes/modules/concommand.lua:69
7. unknown - addons/ulib/lua/ulib/shared/commands.lua:1310
8. unknown - lua/includes/modules/concommand.lua:69
Owner of soul gaming
« Reply #382 on: August 11, 2013, 09:45:29 pm »
I posted on github as well, but can you post your data files for me?  Perhaps they're in the old format?  That would likely cause this.
« Reply #383 on: August 11, 2013, 10:41:58 pm »
They're really old. But I deleted them and it didnt work.
« Last Edit: August 11, 2013, 10:47:01 pm by Tristian Wood »
« Reply #384 on: August 12, 2013, 08:18:06 pm »
Mine works just fine.  Are you updating with the correct SVN (it was changed)?
EDIT:  I also updated the workshop addon.
« Last Edit: August 12, 2013, 08:38:22 pm by Aaron113 »
« Reply #386 on: August 13, 2013, 09:29:45 am »
Can you do me a favor and type "lua_run PrintTable(restrictions)" in your SERVER'S console and post it here for me?  It's saying that there is no table in the error.  If that errors, then something is likely overriding the variable.  Or it isn't loading the data files properly.
« Reply #387 on: August 14, 2013, 05:20:12 am »
I got
[ERROR] lua/includes/util.lua:54: bad argument #1 to 'pairs' (table expected, got nil)
1. pairs - [C]:-1
2. PrintTable - lua/includes/util.lua:54
3. unknown - lua_run:1
When doing it.
I fixed it, I had to delete my old restrictions/limits/loadout files. Is there an easy way to convert the following into the new format?
http://pastebin.com/7qUB491j
Can you add me on steam please: Darkolking -S?-
« Last Edit: August 14, 2013, 05:55:40 am by Tristian Wood »
« Reply #388 on: August 14, 2013, 12:24:16 pm »
So it is your data files.  I honestly am not sure what format it is using.  I'll tinker with it a bit.
EDIT:  If you know what version you were previously using, I could probably help.
« Last Edit: August 14, 2013, 12:35:48 pm by Aaron113 »
« Reply #389 on: August 14, 2013, 11:10:50 pm »
I'm pretty using the following version
« Last Edit: August 14, 2013, 11:21:39 pm by Tristian Wood »
