Author Topic: sui_scoreboard with UTime and Steam Avatars  (Read 184442 times)
Offline SwatCorp
Re: sui_scoreboard with UTime and Steam Avatars
« Reply #30 on: February 02, 2009, 07:47:31 am »
where can i download the version 3 ?
Offline Dv2236
    • MyGamingVoid
« Reply #31 on: February 08, 2009, 01:20:54 pm »
I think that would be "sui_scoreboard_modified_v2-1" even know 2-1=1 haha, a little side joke
Offline Dv2236
    • MyGamingVoid
« Reply #32 on: February 17, 2009, 12:24:03 pm »
they took out avatar support in last update so now this don't work because of the avatar, back to the one i fixed up :S
EDIT/ADD: I like how he did not add my vote button fix before he even released this from the start!?
« Last Edit: February 17, 2009, 12:53:39 pm by Dv2236 »
Offline Cornflake
« Reply #33 on: February 19, 2009, 02:25:45 am »
I thought maybe this was a temporary problem because of the issue with the SteamID change on Tuesday? Can anyone find any information on it?
Also, the release notes for the latest OB Engine update say "Reverted the change that capped rate at 30000". I'm assuming that means the maximum rate for Source games is no longer capped?
Offline LargoUsagi
« Reply #34 on: February 24, 2009, 11:02:08 pm »
well im having the same problem as another user is there a way to not load this when in specific game modes in OSE (onslaught evolved) the screen gets stuck and glitches because the game mode uses its own UI Menus and Scoreboard
Offline Dv2236
    • MyGamingVoid
« Reply #35 on: February 24, 2009, 11:24:21 pm »
I stoped playing gmod for a few days now, I did a update and TF2 went from 54 to 51... so might as well ask does this work again now?
« Reply #36 on: February 25, 2009, 06:18:14 am »
It's worked for me ever since VALVe rolled back the update.
Offline tony
  • Happy Day.
« Reply #37 on: February 27, 2009, 04:41:13 pm »
I made a slightly altered version of this menu for my own server,
In my version the time column reports session time rather than overall time, because personally that is what I'm more interested in. I also removed all of the extra ratings, and left the original ones (sorry guys, I know a lot of time was put into them but they just weren't my cup-o-tea).
If anyone would like this slightly altered version you can PM me. I'm not trying to hyjack the thread or even release something, just letting you guys know I've got it if you want it  ;D
As for the original developers, if you don't like me posting this, let me know via PM and I'll delete the post.
« Reply #38 on: February 27, 2009, 05:11:26 pm »
Feel free to post your version here tony. The original author of the scoreboard gave us permission to modify the board... and since the community has seen no sign of him for years, I assume he won't mind anyone else building off it.
« Reply #39 on: February 27, 2009, 07:44:43 pm »
Be nice and at least mention the author in any credits.
Though many projects I've worked on (coding/documentation/whatever) have ended up only using 5-10% of the original authors works, I often place "Originally based on <blah> by <author>" or "Inspired by <author>"
Offline lolol
« Reply #40 on: April 07, 2009, 05:43:34 am »
Ok, I just downloaded this, and it's awesome! Looks great!
A few issues I'm having though... you need UTime for this... and my UTime is not working, it does not save the time. All it does is show session time. Map restart, rejoin, server restart... poof... time's gone. I don't want UTime on the server if it does not save the time, but I can't remove it because it screws up the scoreboard.
Can someone please make a non UTime dependant version or tell me how to fix my Utime?
I will give you any info you need to solve this issue!
-Adrian (sorry about the "lolol" username, I created it a while ago because I was in need of quick help :P)
EDIT: Wait... I just checked the UTime thread, and it seems as if the VALVe update screwed up something... I guess that's the problem?
« Last Edit: April 07, 2009, 05:46:17 am by lolol »
Offline sparky2002b
  • CloudNine Clan Administrator
« Reply #41 on: April 07, 2009, 02:30:37 pm »
sui_scoreboard breaks non-sandbox gamemodes. Is there any way to disable it from running on anything but Sandbox?
CloudNine Clan Server - 68.64.33.152:27019 - http://c9gc.com
Offline BMCha
« Reply #42 on: April 08, 2009, 05:32:07 pm »
^ I'm not sure if there's  a way to do that. There probably is and it shouldn't be too hard to fix. I may look into it if I have time.
Anyway, I just released a version with all the Utime lines commented out. Attachment in first post.
« Reply #43 on: April 09, 2009, 05:57:37 pm »
I repeatedly see the 'how to disable" request.
Is it really that difficult?
Simplest way possible, allow it to run only in Sandbox mode.
Line 13 of lua\autorun\sui_scoreboard.lua
elseif string.lower(GAMEMODE.Name) == "sandbox" then
Plenty other ways, but thats the most direct.
Use and loop through a table if you want to support more than 2 or 3 gamemodes.
Offline frel
« Reply #44 on: April 13, 2009, 11:24:41 pm »
the no utime version link is down...
