Author Topic: sui_scoreboard with UTime and Steam Avatars  (Read 184442 times)
Offline frel
Re: sui_scoreboard with UTime and Steam Avatars
« Reply #45 on: April 15, 2009, 09:20:45 pm »
Offline frel
« Reply #46 on: April 17, 2009, 11:21:03 am »
5 days later.... no answer
Nice active forum T_T'
I think i have the time to learn lua code and try to fix the code by myself....
« Last Edit: April 17, 2009, 11:25:33 am by frel »
« Reply #47 on: April 17, 2009, 08:24:34 pm »
Frel, we ignore bumpers.
No, this isn't Facepunch, and we prefer it that way. (Or we would have banned you 2 bumps ago)
Our host company had to rebuild our forum recently, some attachments got broken.
The only two people who can (or might) be able to fix it haven't been here in over a week.
(1) The author of this mod. 2) Megiddo, the forum owner )
They're busy. Adjust. Be patient. This is a hobby for us, not a job.
Great, learn Lua. Good idea
Offline frel
« Reply #48 on: April 21, 2009, 08:45:31 am »
When you are an admin, you need to come on your website at least one time per day... That what i do
If you cant do that, its time to give the website to another one. That do almost 10 days im waiting for that and no new...
Same for ULX... how many time we will need to wait for get it work???
Offline loversama
« Reply #49 on: April 21, 2009, 02:46:02 pm »
Use SVN to get it to work, had the same problem.
If you cannot SVN on your server then SVN on your PC then upload to server ^_^
Also, I am waiting for a link to the UTime version of this plugin also, thanks for any replies.
« Reply #50 on: April 21, 2009, 02:56:51 pm »
The admin of this site did not make the program, and can't fix the link.
As I explained before, our hosting company broke the server, and restored from a copy before the link.
The author of this release will have to re-upload.
As for ULX... we're testing in SVN. (Thanks for explaining loversame)
If that answer isn't good enough for you Frel, and you don't want to assist or can't by testing SVN, please go use another admin mod.
I have no patience for supporting you with your current attitude, and my other team mates won't have time.
« Last Edit: April 21, 2009, 02:59:32 pm by JamminR »
Offline frel
« Reply #51 on: April 21, 2009, 07:50:33 pm »
Im using the SVN version and the chat command not working... And admin dont load when i start server
More info here http://www.facepunch.com/showthread.php?t=260947&page=55
« Last Edit: April 21, 2009, 07:53:29 pm by frel »
Offline frel
« Reply #52 on: April 26, 2009, 07:58:36 pm »
How many year ill need to wait before to get this scoreboard???
« Last Edit: April 26, 2009, 08:43:55 pm by frel »
« Reply #53 on: April 26, 2009, 08:49:22 pm »
An extra year is tacked on for every post you waste our time with. The attachment is nowhere on the server, BMCha will need to reupload it. I guess his upload must have coincided with when Dreamhost was having major issues with the server we were on.
Offline benbrooks
« Reply #54 on: April 27, 2009, 04:03:40 pm »
I have a version without uTime available. It's attached to this post.
It has had some edits (Sandbox only, etc.) You should be able to find them and alter to your needs.
« Last Edit: April 27, 2009, 04:07:57 pm by benbrooks »
Offline PowerHouse
« Reply #55 on: May 30, 2009, 08:58:10 pm »
BLAH BLAH BLAH, This thing works perfectly. Great work! ;D
Offline Cashoo
« Reply #56 on: July 07, 2009, 04:35:33 pm »
This one doesn't seem to work in cube gamemode, it just stays up once you press tab and spams some errors.
vgui.Create: Error when calling 'SuiScoreBoard':Init (sui_scoreboard\player_infocard.lua:112: attempt to call method 'GetWebsite' (a nil value))
ERROR: GAMEMODE:'ScoreboardShow' Failed: autorun/sui_scoreboard.lua:44: attempt to index global 'SuiScoreBoard' (a nil value)
sui_scoreboard/scoreboard.lua:239: attempt to index field 'lblPing' (a nil value)
sui_scoreboard/scoreboard.lua:197: attempt to index field 'lblPing' (a nil value)
ERROR: GAMEMODE:'ScoreboardHide' Failed: autorun/sui_scoreboard.lua:56: attempt to index global 'SuiScoreBoard' (a nil value)
« Reply #57 on: July 07, 2009, 07:11:06 pm »
It only works in sandbox derivatives.
Offline Cashoo
« Reply #58 on: July 08, 2009, 12:11:22 am »
So I have to delete it to get it not to show up in other gamemodes?
Offline Lt.Smith
« Reply #59 on: August 24, 2009, 08:46:36 am »
Just a quick post to say thanks: I was looking for this.
