Author Topic: sui_scoreboard with UTime and Steam Avatars  (Read 184442 times)
Offline sharp
Re: sui_scoreboard with UTime and Steam Avatars
« Reply #60 on: November 11, 2009, 12:30:52 am »
I like this scoreboard it works good.  I'm using the one with uteam and utime.
Do you think adding a AFK column to work with the anti AFK Ulib module flag would be a good addition?  just a suggestion.
Offline Glockshna
« Reply #61 on: November 13, 2009, 11:51:48 pm »
Hmm wont let me download it. Says i need to login, but obviously i am logged in :P Any ideas? can someone post a direct link to the download?
thanks.
« Reply #62 on: November 14, 2009, 10:36:15 am »
You don't see the links now that you are logged in?
When I click them from the first post, I get no error message and get prompted to save the file.
Offline Buggzie
« Reply #63 on: June 15, 2010, 06:26:41 am »
Sorry to bump this thread but, When someone changes team for instance they were 'User' and now 'Respected' it will say Resp... until you click on their name. Is there a way to refresh it as soon as teamchange or a player has died?
Thanks!
« Reply #64 on: June 15, 2010, 08:24:03 am »
Easy-- Open lua\sui_scoreboard\player_row.lua, then find the line:
function PANEL:UpdatePlayerData()(around line #120)
Then in that function, find this line of code:
self.lblTeam:SetText( team.GetName(self.Player:Team()) )
...And then add this line of code right under that line:
self.lblTeam:SizeToContents()
I haven't tested it (I'm at work right now), but I'm 90% sure it should work ;D
« Reply #65 on: June 15, 2010, 09:16:14 am »
You know derma entirely to well now Stickly :P
« Reply #66 on: June 15, 2010, 11:06:30 am »
It's a gift.... and a curse!
Offline Buggzie
« Reply #67 on: June 15, 2010, 11:18:16 pm »
vgui.Create: Error when calling 'SuiScoreBoard':Init (sui_scoreboard\scoreboard.lua:76: attempt to index local 'button' (a nil value))
ERROR: GAMEMODE:'ScoreboardShow' Failed: autorun\sui_scoreboard.lua:44: attempt to index global 'SuiScoreBoard' (a nil value)
sui_scoreboard\scoreboard.lua:239: attempt to index field 'lblPing' (a nil value)
sui_scoreboard\scoreboard.lua:197: attempt to index field 'lblPing' (a nil value)
ERROR: GAMEMODE:'ScoreboardHide' Failed: autorun\sui_scoreboard.lua:56: attempt to index global 'SuiScoreBoard' (a nil value)
It broke it..
« Reply #68 on: June 15, 2010, 11:20:49 pm »
Copy/paste the section of code you edited and post it here.
Edit: It SHOULD look something like this: (Depending on whether or not you have the UTime or the non-UTime version)
if ( !self.Player ) then return end
if ( !self.Player:IsValid() ) then return end
// self.lblName:SetText( team.GetName(self.Player:Team()) .." - ".. self.Player:Nick()  )
self.lblName:SetText( self.Player:Nick() )
self.lblHours:SetText( math.floor((self.Player:GetUTime() + CurTime() - self.Player:GetUTimeStart())/60/60))
« Last Edit: June 15, 2010, 11:25:02 pm by Stickly Man! »
Offline Buggzie
« Reply #69 on: June 16, 2010, 06:30:13 pm »
Thats exactly how i did it...
Offline Buggzie
« Reply #70 on: July 10, 2010, 01:55:54 am »
I've been having this slight problem where the hostname takes up quite a while to be on the scoreboard and found a little fix.
Open your /addons/sui_scoreboard_modified_v2/lua/sui_scoreboard/scoreboard.lua
Ctrl+F "self.Hostname:SetText( GetGlobalString( "ServerName" ) )"
Without the quotes.
(You will find two lines exactly matching that above)
Replace them with: "self.Hostname:SetText( GetHostName() )"
(Also without the quotes)
Profit?!?!?
Offline NEM1019
« Reply #71 on: July 11, 2010, 12:19:58 pm »
I've been getting this error contantly, If it's an error or not I don't know
Any ideas?
« Reply #72 on: July 11, 2010, 01:51:30 pm »
Any ideas?
What's wrong?
Offline NEM1019
« Reply #73 on: July 11, 2010, 07:57:46 pm »
Eh, the Logo?
Offline Buggzie
« Reply #74 on: July 11, 2010, 10:14:57 pm »
Eh, the Logo?
other than it looks awesome, i don't understand what you mean, should it not be a g?
